clutch free play
Old Nov 8, 2012 | 05:00 PM
niceprelude's Avatar
Default clutch free play
just put in new master and slave cylinder. pumped and bleed it 20 times,with full clutch fluid. no signs of leaking anywhere ,but it still have free play half way down . please help
Old Nov 8, 2012 | 05:13 PM
civicguy395's Avatar
Default Re: clutch free play
open the cap and then open the bleeder valve untill it has a steady stream comeing out of the valve and then have somebody pump on it a bunch of times and then tell them to hold it to the floor crack the valve back open and let the air out till u get a solid jet of fluid and repeat till you do just like bleeding breaks oh and dont let them let up the peddle till u close the valve back other wise ur just suckin air right back into it
Old Nov 8, 2012 | 05:18 PM
done that exactly 20 times.
Old Nov 8, 2012 | 05:38 PM
doood's Avatar
been there done that
did you adjust the master cylinder?
Old Nov 8, 2012 | 06:08 PM
its not the master cylinder. the clutch sometime goes to the floor and i have to pull it up .but it have pressure have way down
Old Nov 11, 2012 | 03:01 PM
Zeusfire69's Avatar
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/clutch-pedal-freeplay-1953836/
Old Nov 11, 2012 | 05:45 PM
CO671's Avatar
You adjust the rod/pedal play? 14mm bolt for the master cylinder rod where it meets the pedal.
http://autorepair.about.com/od/fixit...dal-height.htm
around 8:30
obuhmyuh
Nov 5, 2007 09:42 PM
r1de4life
Jun 12, 2006 11:23 AM
r1de4life
Jan 16, 2006 10:06 AM
timsch75
Sep 27, 2005 07:46 AM
1SlowSi
Aug 16, 2005 07:24 AM
