re-pin drivers side PW and lock harness ???
I have a 97 DB8 and have the typical problem with my power windows and locks not working all the time cause of the harness running from fender to door getting messed up at the connector.
well last night i pulled my fender off and found that 3 wires actually came out of there pins and I was wondering if anyone had a part number or new a place I could get replacement pins so I can repin my connector..
thanks
Rob
thanks
Rob
I've always had a hard time finding the exact replacement pigtail in the Honda parts catalog so good luck there. The other option is to find somebody parting out their car or going to a junk yard and cutting the connector off that you want (with plenty of wire to work with) and repairing it with that.
You can also check this out: https://honda-tech.com/forums/road-racing-autocross-time-attack-19/official-road-race-electrical-thread-info-questions-builds-only-2771547/
unfortunately there isn't any DC's in the local junk yards around here.. Is there another harness I can look for and just use the pins out of it????
Yes, there are a number of plugs in Honda/Acuras that use the same pins, if you can't find a complete harness, find one with the same pins and pull the plug and as much wire into the door as you can, depin what you need and replace those leads in your car, making the connections inside the door, NOT in the rubber door jamb boot. 94
Are you sure the pins didn't pull out of the connector because the plastic retaining pegs inside the plastic connector have broken (I.e.- Broken connector and not broken pins). You may just need the plastic connector piece. Just a thought.
slowcoupe93
Jul 3, 2007 05:05 PM
