99 TYPE R INTKAE MANIFOLD ON B16A2
Old Nov 8, 2012 | 11:00 AM
WAUKEENEM1's Avatar
Default 99 TYPE R INTKAE MANIFOLD ON B16A2
I'm planning on swapping my oem b16a2 im for a itr im. i read a few posts online on whats parts are needed.
however, some said the only thing you really need are the im gasket, throttle bracket, and tb gasket if you're gonna use the itr tb.
some said you need iacv, fuel rail, tps from a gsr and the rest mention above.
i'm using a holley 68mm tb and itr im. i still have the oem fuel rail. so, what parts are needed for my swap?
thanks
Old Nov 8, 2012 | 11:01 AM
jdmjunkie562's Avatar
Default Re: 99 TYPE R INTKAE MANIFOLD ON B16A2
bump
Old Nov 9, 2012 | 04:16 AM
WAUKEENEM1's Avatar
anyone?
Old Nov 9, 2012 | 07:40 AM
OneBadEM1's Avatar
What engine do you have? if you have the b16 i would just buy a high performance intake manifold for it, thats just my opinion. Good Luck!
Old Nov 9, 2012 | 09:55 AM
WAUKEENEM1's Avatar
fully built b16a2 turbo. i got the manifold when i purchased the car. just thinking about it. i'm gonna flush and install aluminum radiator in the spring. might it as well do it at that time.
Old Nov 9, 2012 | 11:09 AM
Deetz's Avatar
Crazy Honda Guy
If you get your b16 p30 intake manifold ported, it will make more power than the itr P73
Extrude hone has done them with "amazing" results!
nikanoras
18
Feb 17, 2010 06:31 AM
1jdmek
15
Jan 8, 2010 02:45 PM
Sivic87
Apr 16, 2006 07:35 PM
racekar
Aug 15, 2004 12:16 PM
