Electric Water Pump
Old Nov 7, 2012 | 11:47 AM
LM1092's Avatar
Default Electric Water Pump
This might be a noob question but when you install a EWP how do you change the belt layout to accommodate not having a mechanical water pump on a F23A1
Old Nov 7, 2012 | 07:30 PM
jdowen2's Avatar
Default Re: Electric Water Pump
Meizere EWP: These kits replace the OEM timing belt driven water pump with an idler pulley and block off plate. The pumping is performed by a remote pumped spliced into the lower radiator hose. A bracket is supplied to mount the pump to the transaxle. The WP136 Pump was designed for sport compacts, small engine applications and water to air intercoolers. It is well suited for alcohol fueled drag cars.
Old Nov 9, 2012 | 05:20 AM
LM1092's Avatar
http://www.meziere.com/ps-1227-1195-wp50026.aspx#
Found what your talking about... but it looks like I'm gonna have to wait till I do my H22 swap before I can install this cause it says it only fits H series motors
Old Nov 9, 2012 | 09:15 AM
361 accord's Avatar
why would you want to do this anyway?
Old Nov 9, 2012 | 09:16 PM
Hidenplanvew's Avatar
so he can gain the 1 whp... I have seen 1000+ whp hondas with oem waterpumps
Mr_Moos
Jun 24, 2007 10:04 PM
choiboiracing
Sep 28, 2005 07:24 AM
snoop_bealybob
Mar 26, 2003 06:04 PM
d mafia
Oct 29, 2002 03:23 PM
Fooman
Oct 25, 2001 02:47 PM
