1997 h22 high fuel pressure searched, missing on cyl 2 and 4
Old Nov 7, 2012 | 07:48 AM
ef4real's Avatar
Default 1997 h22 high fuel pressure searched, missing on cyl 2 and 4
We just repaired bent valves on the head of this car. The car is all stock except a header. Car had been sitting for around 6 months. We did leakdown test to pinpoint bent valves in cylinder 3. Head is now repaired and back on car. Put some new gas in car, tried to start it and only fires on cylinder 1 and 3. spark plugs from cyl 2 and 4 are wet with gas. We recheck compression cold/ dry test all cylinders are between 150-172 psi. We chech spark good blue spark on all plugs. Put fuel pressure gauge on and we have 60 psi, put on second fpr and make sure return line isnt clogged we still have 60 psi, put on 3rd fpr and now we have like 52 psi. only runs on cyl 1 and 3 for like 15 seconds. thanks for any insight.
Old Nov 7, 2012 | 07:50 AM
ef4real's Avatar
Default Re: 1997 h22 high fuel pressure searched, missing on cyl 2 and 4
Before we put on fuel gauge we siphoned out all gas and replaced fuel filter.
Old Nov 7, 2012 | 09:13 AM
P. Hunter's Avatar
Could the intake ports be clogged? Did you leave rags in there?
Are 1 and 3 plug wires switched?
Old Nov 7, 2012 | 09:15 AM
P. Hunter's Avatar
Did you try swapping plugs?
Old Nov 7, 2012 | 02:54 PM
ef4real's Avatar
good idea i will check the ports, im really thinking it has to do with the fuel pressure though.
Old Nov 7, 2012 | 07:00 PM
P. Hunter's Avatar
your pressure is suppose to be around 47-54psi so you are close on that
Old Nov 8, 2012 | 04:32 AM
ef4real's Avatar
x2 just found that out in factory service manual
Old Nov 8, 2012 | 06:10 AM
P. Hunter's Avatar
i have access to the honda site so if you need any specs or anything just throw me a PM
Old Dec 28, 2012 | 07:01 AM
ef4real's Avatar
I have narrowed it down to weak spark, have switched out dizzy, coil for known good units. Have checked all grounds. ohmed out plug wires they were good? Has anyone experienced these symptoms due to a bad main relay? Also someone else said on here he had gone thru everything in a similar situation and he ended up switching all his fuses and his spark came back nice strong and blue? Any input is appreciated.
Old Dec 29, 2012 | 12:40 AM
holmesnmanny's Avatar
How do you know it's missing on 2 and 4 ? Have you triple checked your spark plug wire firing order ?
lovehondas
Oct 25, 2012 09:56 AM
Silvertc
Sep 23, 2010 09:49 AM
ohboy95c
Jun 1, 2008 10:07 AM
eagleclawracing
Mar 8, 2006 01:01 PM
Chuck Dean
Apr 1, 2004 08:26 AM
