heater not blowing?
Old Nov 6, 2012 | 08:27 PM
civicej897's Avatar
Icon2 heater not blowing?
hello all, i have a 97 civic ex recently my heater has been turining off and on. Then it just stop working. its hooked by running a wire from the harness to the fuse box with on/off switch i bought it like this the actual switch on the heater unit doesnt work so it was always running like it was on 4. So i checked the fuse its not blown now im stumped on what else to look for.Please help i live in new york and its getting cold.
Old Nov 7, 2012 | 01:28 PM
civicej897's Avatar
Default Re: heater not blowing?
None can help, well I replaced the fuse, relay, resistor. Can it be my control unit or blower?
Old Nov 7, 2012 | 11:37 PM
axis11's Avatar
Did you mean the blower motor is turning on and off? When it blows, you get hot air? Points to check: Blower motor, resistor pack, underhood relay, climate control panel.
Old Nov 8, 2012 | 12:12 AM
oversteer_ms's Avatar
Its most likely the blower motor itself.
Ill look up the flow chart tomorrow.
Old Nov 8, 2012 | 05:33 AM
Jo_JDM's Avatar
You might have blown out the motor since you jumped the fuse...
Old Nov 8, 2012 | 05:43 AM
civicej897's Avatar
Yes the heater control switch is broken so what it looks.like is the blower was jump with and on/ off switch and yea it started to go off on it's own and kick back on and now just doesn't turn on at all. Resistor, relay, engine bay fuse have been replaced still nothing blowing basically when I turn the switch on nothing happens no hot air or cold just doesn't blow. Thank you for the replies guys I'll replace the blower but if anything else yall can think of that I can check would be helpful. Thanks again.
Old Nov 8, 2012 | 05:55 AM
axis11's Avatar
If you want the blower and a/c to run like as it should, replace/fix the control panel issue first and restore the wirings like oem. Test the motor with direct 12v supply.
Old Nov 8, 2012 | 06:46 AM
civicej897's Avatar
Ok now can i change the switch itself or or the whole heater/a/c control unit?
Old Nov 8, 2012 | 11:29 PM
axis11's Avatar
The control panel comes in one piece. R & R.
Old Nov 11, 2012 | 10:26 AM
civicej897's Avatar
Icon2 Re: heater not blowing?
Hello all again im back so i checked the blower with 12v and it started spinning. So what if the reisitor is blown will the blower still turn on? Now if its not the resistor can it be the xontrol unit.
Old Nov 11, 2012 | 10:59 AM
civicej897's Avatar
Old Nov 11, 2012 | 01:39 PM
civicej897's Avatar
Thanks for.the help everyone I found the problem to be the control speed switch, by the way is replaceable. Thanks again all.
Old Apr 4, 2013 | 08:23 PM
los94's Avatar
did u have to end up replacing the little slider **** ? mine broke off because it wont move from the middle but the ac and heater work im stuck on how to replace it i got all the parts i need but im not sure on how to take it off
black0hatch
Oct 11, 2012 11:52 PM
Paul26
Apr 8, 2009 01:49 PM
racingcrx
Dec 19, 2008 01:26 AM
autoxthis
Jul 10, 2008 01:41 PM
