Distributor help for H23a vtec
Old Nov 6, 2012 | 06:54 PM
hondaaccordf23's Avatar
Icon2 Distributor help for H23a vtec
Does anyone know what distributor I can use for an h23a vtec blue top engine. It came with the TD-94U which I only found on ebay, but now it's not on there.
I need to know what one I can use with all internal sensor TDC, CKP, and CYP.
Old Nov 6, 2012 | 07:00 PM
99CcordMTF23's Avatar
Default Re: Distributor help for H23a vtec
JDM h22a distributor if you need an internal coil, and an obd1 h22aX distributor if you need the external coil. Isn't the blue top obd2? It should have the crank and tdc sensors on the oil pump? In which case you can use an obd2 p13 external coil distributor from an h22a4. Let me know if you need wiring help. I have it all down on my h22 swap thread.
Old Nov 7, 2012 | 08:37 AM
Thanks and yea it's obd2 but I believe the distributor is obd1 if not it just has all the internal sensors. I just fried my cylinder position sensor. Also I believe my wiring is correct, but I'll let you know.
Old Nov 7, 2012 | 09:16 AM
Also does it matter what year on the JDM H22a distributor im running chipped p28 ecu
like this one
http://www.jdmtigerjapanese.com/hond...-int-coil.html
Old Nov 7, 2012 | 09:22 AM
cvcrcr99's Avatar
I have a OBD1 internal coil H22a distributor is you are interested. Brand new, purchased was rywire about a year ago and just sat in the box.
Old Nov 7, 2012 | 12:13 PM
I'm also running a p28. As long as you have it wired correctly it shouldn't matter on the distributor.
Old Nov 9, 2012 | 12:17 PM
how much you want for it? Also is all the other sensor in it TDC and Crank?
Angeljavier3577
Apr 30, 2018 01:41 PM
FreshCD5
Jun 2, 2011 01:25 PM
Astr8upfella
Jan 20, 2002 01:30 PM
