Vacuum line diameter
Have searched through this tech forum and found the question asked many times, but none with an answer. What are the diameters of the vacuum lines to a D16Z6 engine. Mine are all original and while I think OEM is great, I just want to get the select lengths. My problem with checking my existing hosing is the ends are typically stretched from the nipple they cling to and I dont want to cut them off without a replacement in hand.
Found this elsewhere since I now had a reference to go on.
"95005-35008-10M [ this is a bulk hose, with no numbers printed on it]
95005=type of hose is general applications
35=3.5 mm inner diameter
008=lenght in meters
10M=Gray hose
I took this from motorcycles guides, my guess is that honda have shared parts with cars, I also checked on EPC parts catalogue and the reference ID was the same.
The whole code is described like this
95xxx-yyzzz-w0M
xxx
=== 001- fuel hose
=== 003- vinyl hose
=== 005- vacuum hose
yy
=== several inner diameter starting in 3.0mm
zzz
=== lenght in meters [001,003,005,008]
w
==Fuel hose 2: Red outside braid
===(3 mm inside dia. only)
===5: Black inside braid
===3: Red (3 mm inside dia. only)
===4: Ash gray with red stripe
===6: Black
==Vinyl hose 1: Clear
===2: Black
===3: Light red
===6: Light red
===7: Pale black
==General hose 1: Ash gray
===2: Ash gray
===3: Black
===5: Black
It was taken from http://www.3geez.com/forum/archive/i...p/t-77838.html (please thank them for this info as I googled for the bulk number and found the post)
10M=Gray hose
95xxx-yyzzz-w0M
xxx
=== 001- fuel hose
=== 003- vinyl hose
yy
zzz
w
===6: Black
===2: Black
===3: Light red
===6: Light red
===7: Pale black
===2: Ash gray
===3: Black
===5: Black
