92 vx. fuel pump starting issues
Old Nov 6, 2012 | 10:32 AM
sii.'s Avatar
Default 92 vx. fuel pump starting issues
stock 92 vx. new plugs etc. every once in a while when i turn off the car and i attempt to turn it back on when i turn the key all the way before i start the car the fuel pump doesnt prime and the check engine light wont turn off. but if i wait a minute or two and i try again. the fuel pump will start primeing and the CEL would turn off.. it does this maybe once every other week? ignition coil?
Old Nov 6, 2012 | 11:45 AM
sii.'s Avatar
Default Re: 92 vx. fuel pump starting issues
lmk
Old Nov 6, 2012 | 11:48 AM
judgeDredd's Avatar
main relay just replace mine on my 92 vx, check engine light is probably a separate issue though
Old Nov 7, 2012 | 08:06 AM
sii.'s Avatar
D:
Old Nov 7, 2012 | 03:00 PM
jdmem205's Avatar
Cel is not a separate issue unless after you turn on the car it remains on. The cel turns on n off when starting car cause it's almost a diagnostic thing the car does to tell you if the pump is premiering etc.
This is prolly a bad main relay my car does the same but has stopped from doing it the last month but it has its moments lol. Try getting a new relay and take it from there
z0mbie
Jul 5, 2014 06:39 AM
acidburn2k2
Aug 16, 2010 09:08 AM
Tatooine
Jun 27, 2010 07:00 PM
1988_96hb
10
May 1, 2009 01:10 PM
nicehatchy
Mar 5, 2006 06:57 PM
