1989 honda integra zc idle issue
Old Nov 6, 2012 | 12:20 AM
Charith Wattage's Avatar
Default 1989 honda integra zc idle issue
i have just replaced my cambelt and water pump on my integra and after doing so my zc won't idle. drives perfect just doesn't idle
my ecu is flashing 1 long flash then 7 fast flashes then 9 fast flashes. not sure if it 10, 7, 9 or 1, 7, 9 or 17, 9?
i am confused to what fault code this is showing? i think its either TPS or crank position sensor?
its so frustrating driving in traffic when your car cuts out every time your coming to a stop.
can anyone please help me with this problem.
Old Nov 6, 2012 | 10:46 AM
JuicedUpRice's Avatar
Default Re: 1989 honda integra zc idle issue
i would say your timing is off,and/or you need to do a proper valve adjustment
Old Nov 6, 2012 | 11:29 AM
fcm's Avatar
fcm
Old Fart
Ditto the above^^^ even if it turns out not to be the problem, it is the first thing I would check, [valve and ign. timing] if for no other reason other then to eliminate timing as the issue.
One long and seven short flashes is 17, rthat would be VSS. 94
minspd
Dec 12, 2014 08:09 AM
dillett7799
Aug 18, 2009 02:04 PM
b18hondahb
16
Oct 13, 2006 05:40 PM
