Location of pin 1 on OBD0 plugs
Old Nov 5, 2012 | 08:21 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
Default Location of pin 1 on OBD0 plugs
i have gotten myself confused as to the location of pin 1 on the plug A. B and C on the OBD0 connectors. does anyone have a definitive explanation, or better yet a photo with the pin identified?
Old Nov 5, 2012 | 08:42 PM
Default Re: Location of pin 1 on OBD0 plugs
actually, that diagram is in direct contradiction to another diagram i have found.
EDIT.
this is the correct diagram.
Old Nov 6, 2012 | 07:19 AM
xenocron's Avatar
They are both correct, pictures are always looking in from the back side of the connector that plugs in to the ECU
Old Nov 6, 2012 | 03:08 PM
One states that the sequence is across and the other is down and across.
Old Nov 7, 2012 | 05:32 PM
xenocron's Avatar
you're correct, missed that...top one looks incorrect to me
Old Nov 7, 2012 | 06:29 PM
Cheers, i confirmed that as well, by aligning blank spots on the connector with the diagram. i will remove the incorrect image for the records.
f20cmx5
Mar 28, 2011 09:44 PM
RACEPAK
May 14, 2008 12:00 AM
dx2sicrx
Jun 21, 2005 04:18 PM
PliggityPB
Feb 17, 2003 10:20 PM
mmuller
Dec 27, 2002 05:30 AM
