Is it possible...
Old Nov 5, 2012 | 07:57 PM
RenxStrikes's Avatar
Default Is it possible...
I have a 1990 Acura Integra LS I bought recently, it has a b18b1 motor, I would like to change it from OBD0 to OBD1 or OBD2 is this possible and if so what all do I need to change?
I am relatively new to working on cars... From what I have been able to gather from forums so far is that I would need a new ecu, distrubtor, and o2 sensor... Is that all I would have to change?
Old Nov 5, 2012 | 08:02 PM
kchungb17a's Avatar
Default Re: Is it possible...
What is your goal? Just to switch to a different, newer version of OBD which will increase the scrutiny by which your emissions is measured? (Your answer here should be no). Or are you trying to switch to an engine from a different year? Judging by the way you framed your question, I'm guessing the former. Please give us some insight in your thought process.
Old Nov 5, 2012 | 08:19 PM
Ah sorry, my goal is to turbo the car and I would like to use the s300 by hondata as I have been told it is the best by a few people, it uses the OBD1 connector. Emissions isn't an issue really as where I live isn't to strict on it.. Also right now I can't hook a code reader up to it and its really annoying using jumpers to get the code when I own and obd1 / obd2 code reader.
Old Nov 5, 2012 | 09:20 PM
JuicedUpRice's Avatar
Old Nov 5, 2012 | 09:30 PM
el crapitan's Avatar
obd1 does not have a diagnostic port to read codes
Old Nov 6, 2012 | 05:59 AM
kyden's Avatar
you can't run obd2 with s300 anyway. you'll either have to use a laptop or jumper.
Old Nov 6, 2012 | 06:52 AM
... Thats all besides the point, what do I need to change to get it to be OBD1 or OBD2?
Old Nov 6, 2012 | 09:27 AM
kchungb17a's Avatar
For S300, go OBD1. It looks like you would need an OBD0 to OBD1 jumper harness and an OBD1 distributor:
https://www.google.com/search?q=inte...ient=firefox-a
Old Nov 6, 2012 | 10:32 AM
3rdtimecharmer's Avatar
10 Year Member
let him do what he wants and find out the hard way.
Nick97hatch
Oct 10, 2004 10:56 AM
B16CRXT
Jan 24, 2004 07:16 PM
-16V-
Oct 21, 2002 04:36 AM
twoquickls
May 20, 2002 01:07 AM
GSRGuy17
May 16, 2002 07:42 AM
