1998-2001 OEM Acura Integra Headlights with TSX HID Retrofit Denso Ballasts PNP
asking $400 OBO
Please visit http://www.ebay.com/itm/121032970647...84.m1586.l2649
for all relevant information and additional pictures. I encourage you to make offers through ebay rather than PM's as I rarely check them.
1998-2001 OEM Acura Integra Headlights with an OEM TSX HID Retrofit, D2s bulbs, and Denso Ballasts
Everything was tested and is in perfect working condition (except the included high beam bulbs. I have no way of testing them). All tabs are intact, however one clip is missing (see the red circle in pics). It shouldn't be hard to find one of them and it just slides on.
I took the headlights apart and mounted the TSX projectors myself. It involves cutting off the original Integra projector housing and mounting the TSX projector in its place. I mounted the TSX projectors to the inner bracket using 1" spacers so the TSX lens would sit where the Integra one was. The factory headlight alignment bolts are still functional. To reduce glare, I painted the reflector housing using gray high temp paint.
Here is a how-to: http://www.hidplanet.com/forums/show...ens-Projectors This is just for reference. Again, I used spacers on mine so the lens sits further forward in the housing, more like the stock projectors.
The TSX projectors are the smooth (non-fresnel) ones. They are a matching pair. They are color modded. The color mod involves adding a washer in-between the lens and the bowl of the top of the projector, and it creates a prism effect on the cut off.
The bulbs are Philips D2s. They probably have about 40 hours on them. The ballasts are Denso and I believe they are OEM Lexus. They are Toyota parts.
The set comes with custom harnesses that have been heat shrunk and potted. Plug the harness into the existing headlight plug (ensuring that the black ground wires are mated together. The harnesses are not keyed), and turn them on. Plug and Play!
The pictures with the lights on were taken from about 4' away from the wall to give you a view of the cutoff. The lights are white, the siding is yellow.
aaronISthrowed
Jun 16, 2006 09:13 PM
