Looking for a definite answer on JDM ITR Axles
98 spec JDM integra type R five lug ~ Driver side axle is bad..
I've read numerous threads that you can use CRV axles, but no one supplied a definite answer with a year/model.
I'm looking for something that will bolt right in without modifications.
Can anyone confirm they have did this with hands on experience?
Thank you guys
Thank you guys
Second link supplied is 32mm.. will not fit JDM ITR 36mm. I was just reading and found some info on google that 97 prelude sh axles will work.. direct swap, but cannot confirm.
Just out of curiosity all b-series axles are the same on the transmission side, correct?
I've been told by someone that has done it before.. that 97 base model prelude axles will work both passenger and driver side.. going to order first thing in the morning and will post to let everyone know for future reference.. thank you all for the quick replies!
idk how fast you need them fixed but theres a shop local to me that i use for all of my axle needs. its a prelude/accord outter . they can even rebuild the same bad axle u have.
I just had my friend that works at a local parts store compare a 97 base prelude axle to a 94-01 integra axle the driver side is close to 22 5/8 (integra 94-01) and prelude is 23 5/8.
theres a seller on ebay that has the frankenstein axels on ebay for like 119.00 search integra 36mm axle dont know if there any good or not
Just use 97+ Prelude S axle shafts. They have a 32 mm inner shaft and 36mm outer shaft.
92-96 Prelude axles will NOT work as the inner hub is too big to clear the transmission bell housing.
I do not know if CRV axles will work.
I am using 97 Prelude S axles on my EK, b-series motor/transmission, JDM ITR 5-lug hubs.
However, if you are ever in need of replacing the hub bearings, you will also use 97 + Prelude hub bearings.
SlammedDC2teg
Aug 16, 2005 06:41 PM
