Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
02 EM2 Civic Si Oil Problem
Old Nov 4, 2012 | 06:28 PM
Jason Nucom's Avatar
Default 02 EM2 Civic Si Oil Problem
I Have a 2002 Honda Civic Si that's leaking oil and i cant seem to find the oil leak. Engine bay shows no sign of oil leaks and its also not showing leakage on the floor, Does anyone know where this Oil is Going?!?!
Old Nov 4, 2012 | 07:25 PM
lazlong's Avatar
Default Re: 02 EM2 Civic Si Oil Problem
How much oil are you losing? Any oil in the coolant? Are the sparkplugs nasty covered in oil or carbon? Is it blowing smoke out the exhaust? Shine a light in the sparkplug holes, can you see buildup in the cylinders?
Old Nov 4, 2012 | 10:27 PM
markw's Avatar
If you can't find where it's leaking and you don't have any sign of leakage, then it's not leaking oil. How many miles on it? When you start it after it's sat over night, do you see a puff of blue smoke? Sounds like it's burning oil, not leaking it. My 02 has 177k on it (d17a2) and once I did the head it stopped using oil.
Old Nov 5, 2012 | 05:12 PM
EM2abe's Avatar
find out why you think its leaking oil first and then we can better assist you... it might just be burning oil like a motherb*tch.
Old Nov 5, 2012 | 08:39 PM
its not showing any leakage in the engine bay or on for floor. it was passed due its oil change which is 5000km and i checked my oil and the dipstick was bone dry.
Old Nov 5, 2012 | 09:03 PM
markw's Avatar
If it's using less than 1 quart every 1000 Miles, I wouldn't worry about it. Just check the oil every 2-3 fillups. Cars will use oil.
Old Nov 5, 2012 | 09:16 PM
It Wasn't Me's Avatar
You don't think that's excessive? My Em2 has just under 120k and it uses less than half a quart between oil changes.
Jason, check the PCV to make sure it's functioning properly. You might consider just replacing it. Other things to consider are the valve guides and seals, worn rings, etc. As previously noted, inspect the condition of your spark plugs, too.
SathheshG
May 27, 2017 03:47 PM
masijdm
11
Jan 9, 2009 09:21 PM
hotstuffjsn
Mar 9, 2005 07:11 AM
Bruce_Willis
Dec 17, 2004 08:20 AM
deepnite
Oct 9, 2002 01:46 PM
