Hazard/turn signal problems with rhd eg
Old Nov 4, 2012 | 06:25 PM
smmagoo20's Avatar
Default Hazard/turn signal problems with rhd eg
Ok so here's my problem i have a 92 rhd civic si when i turn on the right turn signal everything works great then when i turn on the left signal only the front bulb works but here's the crazy part. If i turn on the hazard switch the right side still works fine but on the left only the rear bulb works. On another note if i have the left turn signal and hazard switch turned on at the same time left "works" normal. Now for what i have done i borrowed a known working hazard switch and still same problem, I have also bought another turn signal switch for a right hand drive car but its used and unsure if it worked properly. I have checked continuity from the hazard switch to both front and rear bulbs and also from the turn signal switch to the hazard switch everything checks out fine so now im lost so any help would be much appreciated. Thanks
Old Nov 4, 2012 | 07:40 PM
dirty19's Avatar
Ridin Dirty in Cali
Default Re: Hazard/turn signal problems with rhd eg
Do you have rhd bulbs installed ?
Old Nov 6, 2012 | 07:59 PM
smmagoo20's Avatar
haha ya rhd bulbs great idea. Ok now to serious talk, some more updates finally got a working cluster and was messing with it right now and noticed that the indicator light in the cluster doesn't light up either so ya not sure if that means anything but still not getting anywhere with it.
Meraut
Mar 11, 2013 06:34 AM
layinlow4dr
Jan 13, 2010 08:08 AM
Shocka1998LX
Nov 18, 2008 12:50 PM
CB7Tuner915
Mar 16, 2008 11:47 PM
