Door Switch
the door switches? they're attached to the rear door sill (part of the body, not the door) i think you need to take out the panels behind the door and get to the switch from the rear. i think. i was too lazy to do this for my cluster
and if ya didn't know, in order to use the low fuel level light, you need the sensor from a 90-93 teg.
I was hoping you'd post a reply...I manage to get the rear trunk light to work but now I'm pondering on wiring both doors...If I can get a hold of a 90-93 teg fuel sensor, do you know if that's easy to hook up? There are a few junk yards around here that I can check.
88-91 civic wires buddy
ITEM | WIRE COLOR |POL| WIRE LOCATION |
| 12V|white/black |+ |ignition harness |
| STARTER|black/white |+ |ignition harness |
| IGNITION|black/yellow |+ |ignition harness |
| ACCESSORY|yellow |+ |ignition harness |
| SECOND ACCESSORY|blue/white |+ |ignition harness |
| POWER LOCK|green/white |- |in drivers door |
| POWER UNLOCK|green/red |- |in drivers door |
| PARKING LIGHTS +|red/green | |steering column |
| HEADLIGHTS|red/blue |+ |steering columm |
| DOOR TRIGGER|green/red |- |low in drivers kick |
| DOME SUPERVISION|use door trigger | | |
| TRUNK/HATCH PIN|green/black |- |low in drivers kick |
| TACHOMETER|blue | |distributor |
| BRAKE WIRE|green/white |+ |brake switch |
| HORN TRIGGER|blue/red *1 |- |steering column |
Notes:
*1 High-current ground. Use a relay when interfacing with this circuit.
what u need is door trigger and trunk trigger.
its a negative pulse when door(S) and trunk is open.
Notes:
What do you mean by negative pulse? if I find the switch, do I connect it to the negative terminal? is there a switch that activates left and right doors as suppose to a door switch in general?
Kathyle3
Oct 23, 2016 06:21 PM
integra-modder
Jun 26, 2002 08:25 AM
