99 gs hard time turning over and weird idle during warm up.
Well this problem occurs at a 50/50 rate. GS is an automatic all stock with 120k miles on it. I done all general maintenance oil, oil filter air filter and all the other oil treatments and fuel injector cleaner and changed fuel filter and fuel pump. Also cleaned my throttle body, but never fully take all parts off and cleaned it. Also put in a new vapor canister.
My guesses are probably a bad throttle body or timing belt and water pump.
When starting it takes about 3-6 turns and i hold each one for about 3 secs but when i stop turning i hear a faint idle then it dies but when it doesnt die the faint idle lasts for up to 10 sec (sounds like the engine is starving) before the idle jumps up to 2k rpm then takes forever to come down to where it should be. Other things i noticed was under the hood after the car running for only couple minutes everything is hot like not even able to hold the hood stand rod that's how hot it comes.
When i look at my temp gauge its normal and as i drive it all day it never jumps stays at where it should be.
If anyone can give me some tips on what it could be i really much appreciate it.
a fuel pressure gauge would be a good place to start. see what it's reading when the problem occurs.
also, have you checked for any codes? check them. regardless of an illuminated CEL.
one thing you can try is to cycle the key on for 5 seconds. do that a couple times before cranking it. see if it makes a difference. i've got a sneaking suspicion that your residual fuel pressure is bleeding back. either that, or if the car utilizes a FITV, it may be stuck. and if it doesn't utilize a FITV, it could be an ECT sensor issue, since the ECT is the input for fast idle. those are the places i'd look
That could be in the fuel pump, [bleed back valve] but you said you replaced the pump so I am guessing it is the FPR.
As mentioned, turn the ign. switch on, wait untill fuel pump stops priming, turn ign. off and on again, again wait untill fuel pump stops priming, repeat a few times before actually trying to start the engine, let us know what happens.
Also as mentioned, check for codes. 94
The other day i stopped at a mechanics shop and the owner said it sounds like my main relay is going out. He said its very common on honda cars. So im going to fix that also after i scan my car.
And yes i did do the ing. on off etc and it still did the same problem. The weird thing is that it only does this problem after i drive and try to start my car in the next hour...
put a fuel pressure gauge on it and observe pressure when the problem is occurring. it could be the main relay. but could also be ignition related. the gauge will point you in the right direction instead of guessing which way to go with it
http://techauto.tripod.com/mainrelay.htm
http://www.tegger.com/hondafaq/mainrelay.html
Also, you do not need a scanner to check for codes...
http://www.team-integra.net/forum/bl...light-cel.html 94
Okay guys. I did a CEL scan nothing came up, change main relay problem still there, just put on fuel pressure gauge. Not sure how to do the proccess for checking if it is my FPR, but it was between 36 and 40 PSI.... but it also drop close to 30 PSI when i turned off the car and checked the gauged in about 5 min.
Any info guys?
One other thing is, can fuel injecters cause this kind of trouble?
Any info guys?
the pressure will drop with the key off. some loss is normal. i believe 20 psi drop within 30 minutes was the threshold. but that's not your problem here.
was the problem occuring when you read that base fuel pressure?
engine running and gauge installed, your pressure should be between 35-40psi. now, pinch the vac line going to the FPR. pressure should increase by about 10psi. if not, regulator or vac line to regulator is bad. if you get the extra 10psi, line still pinched, snap the throttle 3 times. if the pressure decreased by any more than 2-3psi, there is a flow problem. either the pump is weak or the fuel filter is restricting flow.
if so, i would replace the filter first and retest
So i took off the vaccum hose and the pressure went to 50 psi and when i reconnected it it went down to 40-41 psi... Is that normal? I heard it supposed to go down to around 35 psi. Is my regulator drowning out my intake with fuel and causing my car to have a hard time starting with too much fuel inside?
Hey guys sorry been long since i posted busy working...
Anyways i got a B&M FPR and adjusted it to the right psi on the b18b1 engine. But still the problem occurs. I also noticed that when i put a lil pressure on the gas peddle car starts bogging.
Anyone know what this is? I was thinking the sensor on the throttle body, fuel rail or fuel injectors.
Also checked codes coz Cel came on and the code P147 came up.
Could the sensor on the throttle body or the intake manifold might be no good?
Another assumption could this be anything to do with my timing and water pump or fuel injectors?
Check for vacuum leaks, we use a butane torch, turn it on, [don't light it
] point tip at/along all vac lines/connections, if RPMs go up, you have a vac leak. 94
VersedCivic
May 19, 2014 05:23 PM
6969crx6969
Sep 19, 2010 02:29 PM
maxxdout
Jun 21, 2002 06:04 AM
