92 Civic/D16Z9 - auto transmission seems to stick in second or third gear
Hi Guys, Hope someone can help my get my 92 civic to drive correctly.
I have a 92 civic non US, NON-VTEC, cause of the regulations in my country i can't upgrade the engine to a vtec engine...
My Civic had a few problems with the computer and the engine, so the mechanic put in a used NON-VTEC motor (which runs fine except for the idle control is a little wacky) also the automatic transmission seems like its in limp mode because it won't shift after 80 km/h(4,000 rpm) 90 km/h (5,000 rpm). I went to Honda central garage in Israel and they told me that the car has a VTEC ECU, so i have no idea if the issues are related to the ECU, if its an electrical problem or something completely non related.
Can anybody help me figure out this nightmare?
BTW. Honda told me that they can't get me an ECU for my 92 Civic, does anybody know where i can find one?
Ok we can only help a small bit as your post is very vague.
The wacky idle is most likely the air idle control motor on back of intake manifold. Take off clean with brake clean.
The trans in limp mod, i have no idea has you did not provide any good info on issues other than wont shift.
Ecu-- search junk yards, here on HT (honda marketplace), among other honda forums. You will find one.
Out of not trying to sound stupid, but being a complete newb to honda's the engine is 1.6 L, D16Z9, DOHC I4,
The issue is as follows: Car is idling at about 1000 rpm, start driving in [D] on road from stand still, first shift good second shift good (now i am about 60 km/h, rpm around 3,000), from this point forward transmission no longer shifts the rpm's climb as speed increases (its as if the car is stuck in second or third gear. As an example in my Chevy after i get to about 80-100 km/h if i am not on the throttle the transmission kicks down to a lower rpm, in the honda it just stays at the higher RPM no matter what i do, my fear is if i keep driving at 90km/h over an extended amount of time i will eventually blow up the engine.
so the issue is with ECU from what i understand, because the ECU in my civic right now is for a vtec engine, prior to the mechanic switching out the ECU, it had the proper D16Z9 ECU and the transmission was still doing this, hope this gives more info on the trouble i have
Again. What ECU?
And this
D16Z9
Found in:
1994–1995 Civic Coupé (EJ1) 1.6i ESi European
1994–1995 Civic Sedan (EH5) 1.6i EX US
Bore and Stroke: see D16 Series Engines
Displacement: see D16 Series Engines
Compression: 9.3:1
Power: 130 hp (95.6 kW, 129,2 PS) at 6,600 rpm
Torque: 106 lbf (144 Nm) at 5,200 rpm
Redline: 7,200 rpm
Fuel cut: 7,500 rpm
Valvetrain: SOHC VTEC (4 valves per cylinder)
Fuel control: OBD-1 MPFI
ECU code: P28
So if this is correct your engine is VTEC.
And this
D16Z9
Found in:
Compression: 9.3:1
Redline: 7,200 rpm
Fuel cut: 7,500 rpm
ECU code: P28
I believe the engine is a D16A8, according to wikipedia,
all i know according to the registration is that its a 1992 honda civic DL 4 door sedan, and i am assuming the car came from europe as i am located in the middle east(Israel)
Found in:
1988–1995 Civic/CRX/Concerto (UK/Europe/Australia)
1992–1995 Rover 216/416 GTi (UK/Europe)
1993–1997 Rover 216 Sport Coupé (Europe)
Compression : 9.5:1
Power : 122 PS (90 kW; 120 hp) at 6,800 rpm
Torque : 14.9 kg·m (146 N·m; 108 lb·ft) at 5,900 rpm
Valvetrain : DOHC (4 valves per cylinder)
Fuel Control : OBD-0 and OBD-1 MPFI
ECU Code : PP5 (OBD-0), P29 (OBD-1)
Head Code : PM7
Gearbox : L3
Found in:
Compression : 9.5:1
Head Code : PM7
Gearbox : L3
Make up your mind. Which one is it? Maybe actually look at it and not worry about VINs, registrations and what Wikipedia is telling you? Check the stamp on the engine block.
My next bit of advice is that the next time someone works on your car, make a note of what was done and what was put into it.
And you have yet to tell us which ECU is in it. Look at that too. If you are unsure then post a pic of it.
Thanks, Thats what i just did, the engine is a D16A7 (stamp on the engine block):
The registration states that its a 1992 Civic DX not DL, 4 door sedan
Found in:
1988–1991 Civic 1.6i (GTi) in New Zealand
1988–1989 Civic models in Europe(ED4,ED7)
1995 Civic models in New Zealand (EG4)
1988–1995 Models in South Africa
1994 Civic GTi (New Zealand) (Various Differences and Increased Output)
Ballade SH4 and SR4 ( D16A7 / EE4 )
Rod Length : 137 mm
Compression : 9.6:1
Power : 117 hp (87 kW; 119 PS) at 5,900 rpm
Torque : 13.9 kg·m (136 N·m; 101 lb·ft) at 4,800 rpm
Valvetrain : SOHC, four valves per cylinder
ECU: PM6 (OBD-0) / P27 (OBD-1)
Fuel Control : OBD-0 Multi-point PGM-FI, OBD-1 (NZDM)
Found in:
Rod Length : 137 mm
Compression : 9.6:1
that is the one that is supposed to be, but the shop put in a VTEC ecu. does it make sense that a wrong ecu will screw up not only the gear shifts but also the idles control of the engine?
The ECU is located behind the front passenger kick panel. The type of ECU will be printed on a label(s).
But it sounds like your auto trans may be bad or the shift linkage needs to be adjusted. Any CEL codes?
So i went and got a NON Vtec ECU; model number 37820-P1E-900... Apparently for a 1992 Honda CIVIC DX 4door Sedan, the proper ECU needs to be: 37820-P27-B50
Once i get a hold of this thing i should hopefully be able find out what else is wrong, i am hoping that the issues is just that, hopefully i will know more info in a few days once i get the ECU and install it. I will update this thread once i have some more updates...
