My passenger window rail??
Old Nov 2, 2012 | 03:56 PM
sixtoek's Avatar
Default My passenger window rail??
I have lube and place grease on the track and also the rubber seal where the window track goes. It still goes up slow and im pretty much at a stuck point. I was thinking it might be just the motor ? What do you guys suggest i should do?
Old Nov 2, 2012 | 05:13 PM
yessewey's Avatar
Default Re: My passenger window rail??
Put silicone spray on the tracks not grease and see if that fixes the problem, also be sure to make sure you aligned the tracks correctly because that could also be causing the issue. If all else fails then at that point I think it's safe to say that the motor might be the issue. If anyone else can think of anything I might have skipped over as it's been a few years since I had to deal with that issue.
Old Nov 2, 2012 | 09:11 PM
sixtoek's Avatar
Thanks bro .. ill tey thay tomorrow but is there a special brand or any silcone spray ??
Old Nov 2, 2012 | 09:29 PM
sixtoek's Avatar
Would this product me fine ?
loup05
Nov 22, 2005 12:07 PM
rasinhell
May 20, 2005 12:38 AM
DannyITR
Sep 16, 2004 07:11 PM
aZnjCC
11
Aug 16, 2004 07:51 PM
M0NEYnH0s
Feb 26, 2002 12:18 PM
