Closed Deck H22
Old Nov 2, 2012 | 03:15 PM
LM1092's Avatar
Default Closed Deck H22
Is there a Benefit of having a closed deck H22 vs an open deck H22... I'm pretty sure the Closed deck H22's were in the 92-96 but I heard that the earlier H22's wouldn't pass emission testing has anyone heard this too
Old Nov 3, 2012 | 08:21 PM
nus_dogg's Avatar
Default Re: Closed Deck H22
With closed deck, it's stronger than a open deck as they have more vibration and what not.
Old Nov 3, 2012 | 08:30 PM
10psiLsEf2's Avatar
Closed deck is much stronger,less chance of out of round cylinders.
Better heat distribution
Old Nov 5, 2012 | 12:51 PM
LM1092's Avatar
I assume it would be heavier also correct
Old Nov 5, 2012 | 05:41 PM
v4lu3s's Avatar
RTFM
probably negligible weight difference. it is really not that much material. a lot of the strength is theoretical though as the rings and ring lands go out on stock pistons long before the sleeves have hit their power limit.
Old Nov 5, 2012 | 08:10 PM
10psiLsEf2's Avatar
^ this.
A closed deck probably weighs no more than 10 pounds over the open deck..
the water jackets are still The same.
And yes the rings and ring lands is the weak point on MOST oem pistons.
silly nanny24
Nov 24, 2008 05:41 PM
c61lude
Nov 21, 2006 05:59 PM
95accordh22a
Mar 12, 2005 05:26 PM
tunedbylorange.com
Jun 25, 2004 06:53 AM
Pojazz
Jun 10, 2004 10:59 PM
