OBDI vs. OBDII H22 blocks
Old Jun 9, 2004 | 04:53 PM
Pojazz's Avatar
Default OBDI vs. OBDII H22 blocks
How much stronger are the closed deck H22 blocks than the open decks? Just wondering what the consensus is for approximate max boost on the stock closed deck.
Steve
Old Jun 9, 2004 | 07:29 PM
b00sted93Hatch's Avatar
Default Re: OBDI vs. OBDII H22 blocks (Pojazz)
The problem with h22 blocks is that the ringlands are weak on the piston.
Old Jun 9, 2004 | 07:36 PM
TheShodan's Avatar
Moderator
A phenomenal difference when you build the motor. We did one that was able to run over 532whp based upon the Closed deck block
Old Jun 9, 2004 | 07:56 PM
Jared's Avatar
Default Re: (TheShodan)
Doesn't one of them have bigger mains?
Old Jun 9, 2004 | 10:24 PM
Pojazz's Avatar
on the stock sleeves? I realize the ringlonds are the first thing on the **** list, just wondering if the closed deck H22's are anything as strong as SR20 blocks that im used to working on. The ringlands on a SR20DE (non-turbo) can live to about 22psi-mine saw 24, and they're the first thing to go also when boosting -from sheer power (read everything tuned right).
Old Jun 10, 2004 | 10:59 PM
Pojazz's Avatar
Default Re: (Pojazz)
TTT. Anyone?
LM1092
Nov 5, 2012 08:10 PM
lilrobie69
Jan 24, 2012 04:40 PM
jdm knight
Dec 16, 2006 04:10 PM
95accordh22a
Mar 12, 2005 05:26 PM
tunedbylorange.com
Jun 25, 2004 06:53 AM
