Killswitch.
Old Nov 2, 2012 | 03:14 PM
TORTUGA's Avatar
Icon3 Killswitch.
I have a killswitch wired up to my fuel pump, to what else can i wire up a killswitch and how?
Thanks in advance.
Old Nov 2, 2012 | 03:17 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Killswitch.
Anything you want to interrupt power to.
Old Nov 2, 2012 | 03:19 PM
TORTUGA's Avatar
I would like to interrupt the power to my injectors, how can i do that?
Old Nov 2, 2012 | 03:23 PM
The Grumpiest
Er. The fuel pump will cut fuel to the injectors.
Old Nov 2, 2012 | 03:24 PM
TORTUGA's Avatar
I understand but i just wanted to see if there was any possible way to also cut the fuel to the injectors other than the fuel pump, what would you recommend me to wire it up to?
Old Nov 2, 2012 | 05:19 PM
yessewey's Avatar
You could also wire a killswitch to the ground on the main relay, it kills power to the ecu, injectors, fuel pump etc. If you google "main relay killswitch" you should be able to find a few write-ups on it. Also go to the audio/security section of this site and you should find plenty of other helpful information.
Old Nov 3, 2012 | 11:31 PM
street_racer_271's Avatar
all you do is cut a wire, and connect each end to both ends of the switch. You can put a switch to anything you want. I use to run one between my starter and battery that required a key.
eg:R
Jun 16, 2014 07:15 AM
solesthatgo
Apr 9, 2010 04:55 PM
crxfreak1117
Aug 15, 2009 06:09 AM
5lugSlug
Audio / Security / Video
14
Sep 24, 2005 12:06 PM
kablamo
Jan 4, 2004 07:36 AM
