Tech help please! Passenger side windows/locks inop...
Old Oct 31, 2012 | 06:12 PM
JoshuaVTEC's Avatar
Default Tech help please! Passenger side windows/locks inop...
It's a 2000 Civic Si, has 60k original miles........the passenger side power door locks and windows only work intermittently lately. Doesn't matter if I'm using the switches on my driver side or the ones on the actual passenger side door. They'll work sometimes and then sometimes not. I've checked all the wiring and fuses and everything appears good. I'm baffled, any help!? It's weird.
Old Oct 31, 2012 | 06:14 PM
grumblemarc's Avatar
The Grumpiest
Default Re: Tech help please! Passenger side windows/locks inop...
Define "checked".
Old Nov 1, 2012 | 04:46 AM
Aesthetic Gains's Avatar
Dos Pupusas
Originally Posted by grumblemarc
Define "checked".
Most people asking for help only do visual checks on them. You should know this by now. You've been here long enough.
OP, if it only happens on the passenger side, then I would say remove the door panel and inspect the connectors. A loose or corroded connector could cause your intermittent problem. I wonder if they have some type of shared ground. I would start there for sure.
How skilled are you?
Can you work a DVM?
Old Nov 1, 2012 | 05:38 AM
JoshuaVTEC's Avatar
I did remove the door panel, unplugged and re-plugged all the connectors, checked all the wiring was fixed and in good condition, etc.
Old Nov 1, 2012 | 08:54 AM
NVturbo's Avatar
O.G. triple O.G.
$5 BUCKS says it is the driver side door connector (near the door hinge). Either the wires are pinched or the pins are corroded. 60K miles doesn't mean anything if the car is driven in colder weather. Adverse weather detoriates any car.
Old Nov 2, 2012 | 02:05 AM
JoshuaVTEC's Avatar
Thanks for the tip, I'll check everything once again when I get a sec and let you guys know
XcLuSiVeLy4GoD
Jun 11, 2012 05:28 AM
Accord9422
Mar 5, 2012 05:08 PM
wdutton
Dec 1, 2011 06:52 PM
JasonYo
Jan 24, 2011 02:00 PM
munscher
Jul 26, 2003 07:49 AM
