clutch issues just looking for advice
Old Oct 31, 2012 | 04:41 PM
Mikeyb918's Avatar
Default clutch issues just looking for advice
ok i picked up a 95 gsr yesterday i knew something was going on with the clutch but i got a bad *** deal. so moving on... the clutch pedal has very little movement at all and is hard to get into gear. after it warms up it is almost impossible to get in or out of gear. also while its in gear even with the clutch pedal all the way to the floor the car is still moving forward and jerking if i dont give it enough gas. is this the disc, pp or a master or slave cylinder? ive never had to work on clutch issues. please be gentle i love to drive my car and a casual weekend mechanic not the most knowledgeable thanks
Old Oct 31, 2012 | 04:49 PM
dickdragon's Avatar
Default Re: clutch issues just looking for advice
Sounds like the hydraulics. Could be master or slave. Have you bled the clutch?
Old Oct 31, 2012 | 04:57 PM
Mikeyb918's Avatar
not yet just got the car last night and havent messed with it
Old Oct 31, 2012 | 05:55 PM
tech7903's Avatar
definitely try bleeding the clutch and make sure the slave cylinder is extending all the way. if both of those dont fix it then something is probably stuck between the flywheel and disc which will keep the clutch engaged at all times. i had this problem a few months ago and found part of the metal on the disc had broken off and is what got stuck. good luck
732xghost
Dec 22, 2014 09:29 AM
ac_attak
Jun 7, 2006 11:12 AM
markski037
Dec 21, 2005 05:13 PM
M@
Jul 20, 2005 04:02 PM
92BlackSi
Oct 26, 2004 03:51 PM
