b18c1 Build HELP
Old Oct 31, 2012 | 09:07 AM
Klassic978's Avatar
Default b18c1 Build HELP
This is my first serious serious build, my goal is 200-215whp and am looking for anyone to shed some light on my full b18c1 swap with 5spd LSD tranny
HEAD:
-ported head
-sk2 itanke mani
-sk2 throttle body 68mm port to match
-sk2 high comp valves (standard size, high comp) with there matching dual valve springs and tit. retianers
-sk2 stage 3 tuner cams or some brian crower cams
-golden eagle adj cam gears
-rdx 440 inj.
-walboro 255
RMF rep or PML rep headers
BLOCK:
Usdm ITR pistons on GSR rods?
stock crank
everything tuned by a local tuner on a s300
ANY help/opinions/ or any other info to help me with my build and achieve my goal will be greatly appreciated
Old Oct 31, 2012 | 11:56 AM
Klassic978's Avatar
Default Re: b18c1 Build HELP
Anyone? anything? maybe send a link of a similar build i could compare with
Old Oct 31, 2012 | 02:38 PM
truckman's Avatar
not that I know of
Old Oct 31, 2012 | 03:44 PM
Klassic978's Avatar
-_-
Old Oct 31, 2012 | 05:59 PM
TheShodan's Avatar
Moderator
HEAD:
-ported head
-sk2 itanke mani
-rdx 440 inj.
-walboro 255
BLOCK:
stock crank
Closest I've seen is project SHE. But we used an LS block instead of a GS-R because we wanted more stroke.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/shodan-project-she-2915107/
Old Oct 31, 2012 | 06:06 PM
UncleD's Avatar
I have a similar build but haven't finished tuning yet, probably won't finish until this spring. Do you already have the cams or would you consider doing something else?
Old Oct 31, 2012 | 08:18 PM
TheShodan's Avatar
Moderator
Good question.
Old Nov 1, 2012 | 10:25 AM
Klassic978's Avatar
https://honda-tech.com/forums/showthread.php?t=2915107
thanks for the link !
and no i haven't got the cams yet and yes i am open to pretty anything, what did you have in mind @clean rice?
Old Nov 1, 2012 | 11:40 AM
UncleD's Avatar
What is the motor gonna be used for? What is your desired powerband and max rpm you want to rev?
Old Nov 1, 2012 | 12:17 PM
Klassic978's Avatar
Daily driven street car with just a little more "umpf" to have some fun, not to sure on the powerband, and i'd prb. go with 8500-9k for a max rpm
Old Nov 1, 2012 | 12:36 PM
TheShodan's Avatar
Moderator
Any particular power level goals? 200whp? 230whp? More?
Old Nov 1, 2012 | 01:28 PM
Klassic978's Avatar
200-215whp
Old Nov 1, 2012 | 02:25 PM
UncleD's Avatar
Depending on how well the head flows/who did it, I'd get some cams from DD Tech or maybe try some Pro2's if you're willing to rev that high. Pro1 or Toda B would be a "safe" option too.
Old Nov 1, 2012 | 03:32 PM
Klassic978's Avatar
thanks deff. will look into those brands
Fugly123
Jun 2, 2012 01:57 PM
smoked08
May 7, 2011 09:42 AM
94lsboost
Feb 25, 2005 07:54 PM
