3 piece rim question
Old Oct 30, 2012 | 09:05 PM
MurtazaDSM's Avatar
Default 3 piece rim question
I got a set of work rsbeta and I recently bent a rim I have another set of betas also lol with no tires I was wondering can I just unbolt the face off the rim, and then swap the barrels switch the tires and be good or do I need to put some sorta sealent after? also do I have to take the bolts off in a certain order and then torque them back on or just remove and bolt back on? thanks
Old Oct 31, 2012 | 11:13 AM
MurtazaDSM's Avatar
Default Re: 3 piece rim question
Where the wheel ****** at lol bump
Old Oct 31, 2012 | 01:23 PM
BoostedB16EJ's Avatar
yes you need to use sealant; and just like torquing a wheel down properly you do need to work in star patterns around the wheel. also, don't forget to use blue loctite to seal the bolts into place
Old Oct 31, 2012 | 02:55 PM
toyomatt84's Avatar
Sanji
At work?
Anyways, as BoostedB16EJ stated, you'll need sealant in between the two parts of the barrel, as well as a good bead on the inside (the surface that faces the inside of the tire).
Old Oct 31, 2012 | 10:23 PM
doood's Avatar
been there done that
watch these vids
http://www.ccwheel.com/incs/technica...air_video.html
Old Nov 1, 2012 | 08:34 PM
MurtazaDSM's Avatar
Coo thanks
Old Nov 6, 2012 | 01:04 PM
doc@tirerack's Avatar
Manufacturers would argue that assembly bolts should not be reused after installation as they will "stretch" after being torqued down and will lose some strength once the torque has been released and then reapplied. I know that pretty much everyone reuses the bolts, but thought I'd throw my 2 cents in....
Old Nov 11, 2012 | 08:53 PM
JL_Fitment's Avatar
Use a digital caliper on the bolts and see if it the same tread lenth. If so the reuse thos bitches.lol
BobbyRodriguez
Apr 27, 2011 05:06 PM
egvtec
Jun 23, 2010 05:13 AM
koukis_n_milk
Oct 8, 2007 08:59 PM
glarock
Nov 25, 2004 07:49 AM
CHRIS 1.8
Oct 19, 2002 04:50 PM
