PA/WV: J35A4 w/complete harness, ecu, ignition, key and MORE
PRICE DROP!!! $600 FOR ALL OF IT!!! need to sell asap 412-861-1996
PICS ADDED BELOW!!!!!
a friend crashed her 03 pilot into the front/side the other day and i pulled the engine and associated swap parts cuz i was thinking of swapping it into my coupe like (cd7 accord sir) did-sorry if i effed up his SN!! but im strapped for cash now so im thinking of selling this or my turbo kit for my f - which is also complete basically......
i just pulled a j35a4 engine(240hp,240tq) out of a2003 pilot with 157800. engine runs 100%, have video before i pulled.
has complete wire harness to ecu
has matching ecu with ignition, ignition key - all this is needed for swap to start.
also have a auto J32A2 ecu to go with it. this was the ecu i was eventually gonna use and i took time to source. a rezl 2003 acura cl-s type s ecu
also has the throttle cable, dtc connector(so u can wire up the obd2 port) and plenty more little parts needed so you dont have to source them anywhere else. i was gonna use these parts but i need the cash instead.
these engines can be bought for $450ish-JUST FOR THE ENGINE. i will take offers on all this stuff. ALL YOU NEED ARE MOUNTS FOR YOUR SWAP AND THE 6 SPEED TRANS AND AXLES. you can wire up your own harness or send this one out with your harness to don at rpmsystems in NY or API in arizona.
i will take around $700 for all this OBO. this is the most compete V6 swap within a few hundred miles...
i will have pics up in a few
412-861-1996 call me or text if you are serious
located in southwest pa on the west virginia border near WVU
dtc connector and 14 pin plug u will need - i also have the 10 pin u need
matching key
throttle cable
fuse boxes you can have with
MAKE AN OFFER COME GET IT!!!!!!!!!
412-861-1996
matching key
throttle cable
412-861-1996
orientalgunz_00
Jul 13, 2006 02:38 AM
