96-00 power to manual rack and pinion swap
Whats up guys , Im currently running a looped ps rack on my car ( 00 ej8) i just did the breather set up but i have yet to drive the car with the breather set up , Im considering swaping to a 96-00 manual rack , for those of you who have done it i have a couple of questions,
is it easier to turn the wheel while stationary? would the difference be that noticeable with a manual than a looped set up?
Do i need to change the subframe too for a manual one ( i looked through majestic honda part numbers for the subframe between PS and non PS and they seem to be the same.
Yes, a manual rack is geared lower for less operator effort.
Yes.
If the part numbers are the same then no. The '92 - '95 Civics had different subframes and while you could use a power subframe with a manual rack it required shimming up a bushing. IIRC the lower universal joint on the column needs to be swapped as well.
Yes.
Yes.
Interested in the truth on the 96-00 conversion also.
There's as many posts claiming the auto rack converted to manual has a more desirable steering ratio than the factory manual.
It depends on what your definition of desirable is. A looped power rack is quicker lock to lock. A proper manual rack steers easier at the expense of not turning as quick.
Well another thing is that your not pushing fluid thru the system like the manual.even with pump deleted and looped, your still pushing fluid from side to side.
Also, yoou will need the joint that connects the column to the rack. its 29 bucks.
I call it a rag joint, idk what honda calls it
The big question I have is the "Joint B Steering" Everyone keeps quoting the part 53323-S04-003 as if it's the part you need, but that is the only part listed for my HX, which as far as I know only came with power steering. The CX model has two part numbers listed, since it was offered with both power and manual steering. I'm thinking the proper steering joint is 53323-SM4-013. It's the first on the CX parts list, and of course it doesn't show up for cars that only came with PS. Can anyone who has swapped power rack for manual confirm this???
Thanks!
J . K .
Apr 12, 2010 02:16 AM
