F22B2 non Vtec Oil leak/burning
Old Oct 30, 2012 | 07:33 AM
Mr Non Vtec's Avatar
Default F22B2 non Vtec Oil leak/burning
Alright a little background since i'm brand spanking new. I recently totalled my 1997 Blazer S10 4 door (clean clean clean). two weeks ago bought a 1995 Honda Accord 5 Speed F22B2 and alls been good so far but i seem to be burning oil on the block and evidence is all over the top end, i'm working on buying a jack and stands low enough for the car but i took some pics from the top end maybe an estimation of what it could be was the goal.
Sorry if they're too big! this is my first post, and thank you for the help!
Old Oct 30, 2012 | 08:41 AM
Lost Again's Avatar
Default Re: F22B2 non Vtec Oil leak/burning
You can pull the upper part of the timing cover and run the engine and inspect the area for the source...vc gasket, cam seal??
Old Oct 30, 2012 | 08:51 AM
djkurious's Avatar
When was the timing belt and seals last changed?
Also, you need to take those timing belt covers off to see the leaks better. One thing for sure, I am sure the cam seal and/or valve cover gasket is leaking. That is why you get the pool of oil on the cliff of the block.
Look at my pic and you will see the route the oil takes when getting to the "cliff."
Old Oct 30, 2012 | 11:25 AM
So i took the valve cover off
If more pics are needed i can do it but later on, thanks
Old Oct 30, 2012 | 11:27 AM
djkurious's Avatar
Remove that timing belt cover (top), and possibly the bottom cover also. It involves a little more work, but it will show the leaks.
Old Oct 30, 2012 | 11:33 AM
Alright, i'll handle it my next day off thanks again! Friday =P
Old Oct 30, 2012 | 11:42 AM
accorse07's Avatar
If your going to remove your valve cover again and delve in deeper to find an oil leak...go out and get at the very least a new top end gasket kit and a tube of Hondabond for your motor.
Old Oct 30, 2012 | 12:26 PM
Lost Again's Avatar
Add a dab of silicone to the corners of the head where the gasket contacts the "hump". Do the other end as well. In the pic I'm highlighting the gasket, translate that to the head.
Old Oct 30, 2012 | 05:44 PM
Perez_cb7's Avatar
the last thing you want to do is put silicone on the engine if its burning oil your valve seals need to be redone if its leaking oil you need to replace the gasket
Old Oct 31, 2012 | 05:04 AM
Lost Again's Avatar
Really?
From the FSM I have.....and what I do every time.
Old Apr 18, 2013 | 04:23 AM
tomred911's Avatar
Is there a tutorial or step by step instructions on how to change the cam seal. I have the exact same leak!!!
Very frustrating. Thank you
Old Apr 19, 2013 | 12:34 AM
holmesnmanny's Avatar
20 minutes might be fine for hondabond but if you're using rtv, wait atleast an hour
Old Apr 19, 2013 | 07:11 AM
ReaperMan's Avatar
remember the BACK of the valve cover could be leaking as well take that into considerations
Old Apr 21, 2013 | 06:29 AM
Lost Again's Avatar
Are you going to change the timing belts at the same time or just replace the seal?
Old Apr 23, 2013 | 02:37 AM
tomred911's Avatar
No the timing belt and head are new. The belt broke before and I had a shop change those last year. But the car sat for six months because I didnt need to use it. Now the engine is leaking. I changed the valve cover gasket but that didnt help. I was hoping it wanst too involved.
MikeD21
Transmission & Drivetrain
Jan 1, 2019 09:11 AM
Accord_v6mt
May 13, 2015 05:59 PM
wgbm92
Dec 30, 2012 10:26 AM
Root of all Evil
22
Mar 13, 2008 02:09 PM
cw98typer
Dec 5, 2002 02:59 PM
