1994 Accord EX ABS DELETE Q's
Hey, new guy here.
Looking to free up some space in my engine bay, more than likely will boost it eventually and I already have done a partial wire tuck and relocated the battery to the trunk.
I've had an ABS light for awhile now and I know how to pump my brakes, living in Minnesota with older cars teaches you that real quick.. I'm going to leave the components in (ABS control module, sensors, etc.) but remove the fuse box physical ABS module/distro block, and hard lines so if I ever feel the need to re-install it I can.
What do I need to buy? I'm fairly sure the brake line fittings are 10x1, but do I need to buy a new master cylinder (due to only having two output lines) to accommodate four? Or can I buy some sort of T/splitter? I was thinking about ripping a non ABS master off of a junkyard Accord but they're pretty rare around here at least.
Suggestions!
Suggestions!
You can still use your EX MC. Here are a couple of links that should help you.
http://www.accordinglydone.com/forum...isc-Conversion
http://www.accordinglydone.com/forum...aster-Cylinder
There is one of those proportioning valves on a completely totaled 97 Accord at the local yard, almost picked it up too (Also stole a nice mint grille for $15) awesome! Could I just have two braided lines made up at my local auto store too? What size are they usually?
xBoosted4drx
May 3, 2005 10:39 AM
