93 Civic - grinding noise after making a swap
Hi i have a 93 civic coupe ex i just made a swap; about two weeks ago it made this grinding noise i thought it was the trans. So i pit another one and it started making the same noise. Can you please tell me what it is thanks.
You need to be a lot more specific. You did an engine swap? What engine? It grinds when you shift? All the time? With the clutch in or out? Did you do a clutch kit with it? What transmission did you use?
Please create a thread title that summarizes your technical problem/question so that members may quickly understand the topic without reading your post. This helps you to get more and better responses by letting our members know what technical information that you need -- Title edited.
jroderick619
12
Mar 21, 2013 12:26 PM
joelmatt89
Jun 14, 2011 07:54 AM
