Welding head flanges-mounting heatsink
i use 3/8". some use 3/8" and some use 1/2". the warping is inevitable though no matter what u do or use. a good industrial belt sander with some ***** is ur best friend.
mike
mike
Mike, Do you choose aluminum or steel for yours?
I was going to get 1" thick aluminum to use but if thats really overkill I wont bother.
If you can afford it, and block of steel 6" sq. then, just drill and tap the bolt pattern for the flange. You can also attach it to a pipe and it can be used in an engine stand. Do 4 different patterns too!
For all of my manifolds I try and make the connection of each runner as tight as possible and use low amp settings and move as fast as I can....so that the heat you are inducing is as little as posible.
Another thing that I have tryed is after I weld the entire manifold.....I'll leave in the jig and put it inside a baker's furnace at 500 deg for about an hour to detension the manifold.
But I think that if you use a jig with a big steel plate that had a flat surface and weld it with low amps.....it OK
Something like this
Note that the steel plate is 15 mm thick and was flatened before!
Something like this
To revive this thread:
I ended up with a 6"x 5/8" length of aluminum. It works pretty well.
I will have to load up some pics shortly.
if i were to reccomend it to anyone, aluminum is great, but steel you can weld your jigs to easier.
I've seen someone on here use box tubing with hose fittings welded onto the ends and pumped cold water through it while they made their manifolds. Seemed like a pretty simple idea
@racepak......No it's an sr20det (Nissan Sunny / Pulsar GTIR)
And I can sustain what Mike said.......no matter what I'll do...there's still some warping due to the welds on the runners themselves (I mean, that there's some contraction / expanding during the welding process)
I literally use a heatsink
http://www.flickr.com/photos/67031861@N08/7213467086/http://www.flickr.com/photos/67031861@N08/7213467086/ by http://www.flickr.com/people/67031861@N08/, on Flickr
i just went online and found an already fu(ked up head that was still intact on the exhaust side and used that, then just put it in the bottom of the shelf until i ever need it again. also has a good top surface too, so i use it for welding on my valve cover
For welding long head flanges (BMW stuff is long in line 6) I made a fixture:
http://www.flickr.com/photos/67031861@N08/8418022176/http://www.flickr.com/photos/67031861@N08/8418022176/ by http://www.flickr.com/people/67031861@N08/, on Flickr
Who is Mr Robot?
A local guy uses a big chunk of scrap copper, its around 1-1.5" thick, can't remember overall size. But it will suck the heat out of anything with the quickness...
I know this is old..
Apologies for posting in it-
Has anyone tried to use an I beam piece? I see them at my local metal yard in 24" sections often and I would think its big enough not to warp
has anyone tried it?
I now use a piece of solid 2" thick steel. it works much better than the aluminum.
the 2" steel block can surprisingly get extremely hot after welding the runners onto a manifold.
1.6L Miata EFR Manifold by HellaFab Fabrication, on Flickr
ive since lightened the jig and weld off of it.
1.6L Miata EFR Manifold by HellaFab Fabrication, on Flickrive since lightened the jig and weld off of it.
