No spark, need help
Old Oct 29, 2012 | 09:50 AM
Dakine69302's Avatar
Default No spark, need help
I have a 96 accord ex with the 2.2 l vtec and I just did an engine seal because I blew up the timing belt on the old engine. So I put in the newer engine that only has 37,000 miles and now I don't have spark. I had the distributor replaced less than a year ago and put that on the new engine, and it looks like I get a faint spark every once in a while but that's it. Any ideas?
Old Oct 29, 2012 | 10:23 AM
jdowen2's Avatar
Default Re: No spark, need help
Battery connections good. Battery has good voltage? Loose connection?
Old Oct 29, 2012 | 11:34 AM
Good connection, good grounds, everything's good and the same as it was before, just a new block
Old Oct 29, 2012 | 12:35 PM
GhostAccord's Avatar
No spark = loose or dirty ground or an issue with your ignition.
Check all of the grounds, specially the one that is mounted to the drivers side end of the upper intake plenum. That is the main ground for the ECU, G101.
Also you could check for voltage to the coil and ignitor. You have to trace the loss of power from the spark plugs back to the ignition module.
Do you have a shop manual for your Accord?
Old Oct 30, 2012 | 06:23 AM
Lost Again's Avatar
X2 on G101
Old Oct 30, 2012 | 06:29 AM
skyler84's Avatar
mark4586529
Honda Civic (2001 - 2005)
Nov 11, 2018 01:07 PM
tinavagurly
Dec 15, 2017 09:38 PM
landscapenate10
Jul 12, 2008 05:18 PM
dskater411
Mar 28, 2008 09:36 PM
eccentric.ek
Jan 12, 2003 10:20 PM
