93 eg coupe w/ d15z1 - hesitation and sputtering problems
Old Oct 29, 2012 | 07:00 AM
Civic361's Avatar
Icon3 93 eg coupe w/ d15z1 - hesitation and sputtering problems
i got a 93 eg coupe has a d15z1 in it ok well once i get goin i feel a lil hesitation in her esp. when vtec kicks in it sputters then goes let me know if you can help thanks........
Old Oct 29, 2012 | 07:01 AM
D-Vice's Avatar
Default Re: 93 eg coupe
check the oil level?
Old Oct 29, 2012 | 07:24 AM
Civic361's Avatar
jus did an oil change on her......still hesitation and now its tickin or tappin :/
Old Oct 29, 2012 | 08:54 AM
FrodeyEJ1's Avatar
check all of the ignition/fuel components
start with fuel pump/dizzy
Old Oct 29, 2012 | 10:58 AM
HondaMyWayOfLyf's Avatar
Default Re: 93 eg coupe w/ d15z1 - hesitation and sputtering problems
my 94 ls did this under heavier load of the pedal...try ur TPS mine was bad....unplugged it since i was selling the car to a buddy and it worked again up till he totaled the car lol
Old Oct 29, 2012 | 02:08 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
What ECU? And how can you tell when Vtec kicks in? My z1 showed no signs when going into vtec!
Old Oct 29, 2012 | 02:11 PM
Eddie's Avatar
Master Ninja
D15Z1 has no v-tec
Old Oct 29, 2012 | 02:45 PM
Originally Posted by RI5ING SUN
D15Z1 has no v-tec
WRONG. The Z1 is the only Vtec motor that doesn't use vtec for performance but for fuel economy!!!
Old Oct 29, 2012 | 03:25 PM
Eddie's Avatar
Master Ninja
Relax brotato. I have the same motor VX hatch. Yes v-tec e is what the OP is looking for. Was reading as if the OP was looking for performance.
Old Oct 29, 2012 | 07:40 PM
Civic361's Avatar
Ill start with sensor then fuel and spark and has a p28 ecu
Old Oct 29, 2012 | 08:25 PM
Is the ecu chipped with a base map for the z1?
bronman69
Nov 17, 2012 01:23 AM
meric0786
Mar 16, 2010 09:19 AM
SOHCannon
Mar 6, 2010 07:09 PM
JaydmEg
Jan 21, 2009 07:20 PM
WIDEBODYEGCIVIC
Jan 22, 2002 06:29 AM
