AEM question???
Old Oct 28, 2012 | 03:47 AM
J.Berta's Avatar
Default AEM question???
Anyone here running AEM v2? and in coil on plug setup? if so, what can you make of this???
Just received my AEM v2 back from AEM as i can not get my a/c to work with this thing. They said they couldn't find anything wrong with my ecu and they supposedly got the a/c to work on 2 other cars there. It still doesn't work in mines!!. But the a/c works with a regular ecu or my Hondata ecu. Just seeing if anyone had any issues like this from AEM before.
Before the ecu was sent off the A/C control wire only had 6 volts at all times till you try to turn on the a/c. Then it would drop to 1.6 volts. After receiving the ecu back, the a/c control wire has 12 volts and drops around 2.6 volts.. fan comes on just no voltage being sent to the a/c compressor. And i can invert the switch and the compressor will kick on!! just wont come on in a regular situation. And i have changed out the climate control switches and changed the a/c diode as well. and still no good... I hope someone here has some guidance to want is going on!
Old Oct 29, 2012 | 12:52 PM
J.Berta's Avatar
Default Re: AEM question???
Any help?
Old Oct 29, 2012 | 03:16 PM
doood's Avatar
been there done that
you'd get better responses in the ecu/tuning forum. also, not once did you mention the motor setup or chassis.
Old Oct 29, 2012 | 03:45 PM
fcm's Avatar
fcm
Old Fart
If the A/C works with the stock or Hondata ECU/ECM then the problem must be the AEM ECU/ECM or wiring to it.
Is there an adapter harness/jumper for the AEM unit?
As mentioned, MM&Y of cars and any mods/swaps would help. 94
Old Oct 29, 2012 | 06:51 PM
crzycivic93's Avatar
tttt
Old Oct 30, 2012 | 03:00 AM
J.Berta's Avatar
It is in a 95 Integra w/ B-series engine. And I set the ecu back to distributor settings and it still won't control the a/c. Using in distributor setup I'm hooking it up directly with no jumper harness. I tried it in a friends car as well and no luck. And his car is as stock as straight off show room floor.
Old Oct 30, 2012 | 05:10 AM
J.Berta's Avatar
And I just posted this in the ecu management section. So I'm sure it would be in the correct place as stated before. Thanks
johnsc2235
Engine Management and Tuning
May 12, 2014 07:52 AM
J.Berta
Dec 21, 2012 11:07 AM
j-bird20
Nov 26, 2006 09:34 PM
Rabid Machina
Jan 15, 2006 09:45 PM
