transmission m2s4 help
Old Oct 27, 2012 | 02:59 PM
93sivtec's Avatar
Default transmission m2s4 help
hey I was wondering how hard it is to swap the internals on my ms24, and if there are any write ups someone could lead me to.I checked the faq page but didnt see anything.Basically Im experiencing pop outs in 4th and 5th gears in my current ms24, I have a low milage ms24 with a cracked bell housing. So I opened up the extra diff and inspected everything and the syncros and it looks clean as a whistle, very little to no wear on anything.
So instead of buying another used tranny , I was going to try to swap the internals, and replace all of the seals and the thrust shim cause the pass side halfshaft was seeping. Thanks
Old Oct 27, 2012 | 03:04 PM
93sivtec's Avatar
Default Re: transmission m2s4 help
also besides a bearing puller and some feeler gauges,,,,what specialty tools are needed? thanks again
Old Nov 2, 2012 | 08:28 AM
93sivtec's Avatar
bump....anyone? guess not
Old Nov 2, 2012 | 11:46 AM
snobordboy's Avatar
Moderator
As long as you are patient it should not be too bad, most Honda trannys are easy to deal with.
If you look in the FAQs page, there are service manual links now, and the whole process and tools used are in there.
Old Nov 3, 2012 | 08:41 AM
93sivtec's Avatar
thx sno board....I have a a service manual,an actual honda manual not a haynes or chiltton....and it definately makes it look easy, very detailed and in depth.I was just kinda wondering if there is anything I need to be extra carefull of or look out for , and besides a bearing puller and calipers/micrometers for measuring.....are there any speacialty tools I need?
Old Nov 3, 2012 | 08:42 AM
93sivtec's Avatar
I looked in faq's and didnt see it? hummmmm?
barbii
Honda Civic (2001 - 2005)
Jun 7, 2010 02:39 PM
barbii
Jun 6, 2010 11:11 AM
2point2
May 5, 2007 02:17 PM
WRXnomore
Jan 28, 2007 03:21 PM
spoolinegsr
Feb 7, 2006 03:16 PM
