mtx wideband-factory p72 ecu
Old Oct 27, 2012 | 11:42 AM
EkChuck's Avatar
Default mtx wideband-factory p72 ecu
Ok so ive done ton's of research on this and cant find an exact answer. I just installed my Innovate mtx wideband and it works great, now that i no longer have a factory o2 sensor i was wondering what wire Brown/Yellow go to the factory ecu to tell it what to do? I found info on using pin location d10,d11,d12 but cant get an exact answer. I also under stand that i need to adjust the voltage range for wideband to correctly work with the ecu, whats that voltage range? thanks in advance for any help.
Old Oct 29, 2012 | 01:29 PM
EkChuck's Avatar
Default Re: mtx wideband-factory p72 ecu
96 views and no one has anything?
Old Oct 29, 2012 | 02:51 PM
Spunkster's Avatar
With a stock ECU you will not be able to do this. You must use a tunable ECU such as Hondata in order for this to work.
Old Oct 29, 2012 | 04:41 PM
GhostAccord's Avatar
D14 is the narrow band input and you can use ether the YEL or BRN analog out wire from the Wideband O2 controller. It is all in the settings from the controller using LM Programmer. Whatever wire you use make sure that you select that one when configuring the analog output in the LM Programmer software.
The narrow band voltage is from 0.00 - 1.00
0.00 - 19.11 afr
0.30 - 14.7 afr
0.70 - 14.7 afr
1.00 - 10.29 afr
Old Oct 30, 2012 | 04:51 PM
EkChuck's Avatar
Gotcha thanks
Old Nov 20, 2012 | 01:29 PM
ghosthatch's Avatar
0.00 - 19.11 afr
0.30 - 14.7 afr
0.70 - 14.7 afr
1.00 - 10.29 afr
so wait. you CAN do it without tuning software? or not? or are you saying you can do it using the narrow band wire, but then itll still only read like a narrow?
im confused
Old Nov 22, 2012 | 07:14 PM
VegasInvasion's Avatar
I'm Huge In Japan
The stock ECU only reads and corrects for 14.7:1 AFR. It goes to pin D14. Reprogram either wire to the narrowband voltages listed above and it'll function like a stock ECU.
If you want it to correct wideband AFR for performance, the ECU has to be chipped and tuned, there is no alternative.
Old Nov 23, 2012 | 08:03 PM
ghosthatch's Avatar
what if i have a safc 2?
Old Nov 24, 2012 | 05:23 AM
spAdam's Avatar
Loved
Community Favorite
You can still use only use the narrowband output for closed loop operation. You can use the wideband display to adjust your open loop behavior with the safc. Best bet is to get into something like neptune or hondata though.
Bottom line is that the stock ecu does not have the capability to read the 0-5v output of he wideband. Even if it did it can't do anything with the information.
Old Nov 24, 2012 | 03:24 PM
I'm Huge In Japan
Treyschls
Dec 11, 2014 07:49 PM
Honda4life777
Engine Management and Tuning
Jul 10, 2009 06:06 PM
drintegra
Jan 10, 2007 01:15 PM
sanfriz
Mar 26, 2006 11:06 PM
