ef9 Si k20z3 starting issue
Old Oct 26, 2012 | 09:01 PM
xileap2's Avatar
Default ef9 Si k20z3 starting issue
Car is still under construction, but had the motor running before this started.
To the swap. Its a 2009 z3 with 39k in a 90 Si using HR conversion harness and prb kpro.
From the beginning I had issues with the conversion harness and main relay. Then it was the problem of not being able to go above 20psi. When I finally got that fixed and had the motor running, I went ahead And shut it off. After that, never started again.
Checked all my fuses and all was good, realized I had no power coming from my ignition. So I switched out the ignition harness and was getting crank again, but wouldn't turn over.Realized later that I had no power out of fuse number 2(starter relay.) Fuse is good though(no power with multi meter though.) Switched it for another fuse and still no power with the ignition ON.
Luckily for me, I have my CRX. I switched the whole fuse box, ignition and ignition harness and have the same problem.*When I remove the fuse and put the multi meter in the nunber 2 slot, I get .60v, but as soon as I install a fuse, I get no voltage.
Four days on this **** and im just giving up. Hope you guys could help me.*Ask me any question and I could tell you what I've done and havent done.
Any help we be appreciated
Thanks
DC2GSR808
May 6, 2015 09:34 PM
GSRinmyCRX
10
Apr 14, 2011 04:07 AM
8520
Jan 17, 2008 02:49 PM
ef9_pr0jekt
Audio / Security / Video
Aug 11, 2006 04:07 AM
