92 Civic CEL 43 help?
Old Oct 26, 2012 | 04:53 PM
Beegee208080's Avatar
Default 92 Civic CEL 43 help?
'92 Civic LX, 1.6L, 5 speed manual, 240K miles
A while back car wouldn't start and in the process of fixing it have new plugs, wires, cap, rotor, ignition coil; then for jollies I put on a new fuel pump and changed the air filter; fuel pressure was in spec. Ran like a dream after that.
4 months later, after driving for awhile and seemingly only on the highway, it feels like the car is 'slipping'. I can't really describe it any better than this right now. Occassionally when this happens the CEL will come on (but not nessecarily WHILE it's slipping). But sometimes it doesn't come on and I still experience this. It doesn't happen when going for a quick drive down the street.
Pulled the CEL code and I get 43 before and after reset indicitive of FUEL SUPPLY SYSTEM. When began to happen I thought something was maybe wrong with the clutch(and or transmission in general, its never been replaced), but inadequate fuel supply I can see causing similar symptoms.
What would you all knowing experts reccomend to diagnose/fix the problem?
Thanks for your help
Old Oct 26, 2012 | 08:57 PM
Former User's Avatar
Default Re: 92 Civic CEL 43 help?
Recheck the fuel pressure and FPR, and also check for clogged fuel injectors.
Old Oct 26, 2012 | 10:59 PM
do you think this is in anyway related to the transmission?
Old Oct 27, 2012 | 06:44 AM
Not code 43
Old Nov 11, 2012 | 02:30 PM
I've been busy and haven't worked on this yet, but a honda-mechanic friend of a friend mentioned to me that it also could likely be the oxygen sensor malfunctioning/going bad/not working properly.
He said this is inline with the CEL code 43 and also how the light doesn't go on unless in driving on the highway for 20 minutes or so....
fuel pressure and injector clogs are easy to check so I'll probably just check those first.
What do you guys think about the problem being the oxygen sensor? Any direct diagnostic for that or is it a "plug a new one in and see if the problem goes away" sort of thing?
Old Nov 12, 2012 | 12:05 PM
Bump.
Seems like the O2 sensor is consistent CEL 43 based on what the manual says.
Im curious what to make of the fact that the car only has these performance issues (and the CEL only comes on) after driving on highway for some time. What does that signify, and is it consistent with a bad O2 sensor?
What's the relation between the engine temperature+O2 sensor+car performance?
Im curious to the theory of how these things work more so than just trying to fix it and make the problem go away, any thoughtful comments very welcomed
Thanks
Leon.McCo92
12
Mar 5, 2016 07:01 PM
customrice
16
Feb 13, 2012 06:24 PM
19cIvIc94
Mar 2, 2009 12:03 AM
zippo1130
Jan 16, 2008 04:40 PM
Buckshot
Aug 3, 2002 08:40 PM
