Cv Axle And Cv Axle Seal
Old Oct 25, 2012 | 11:28 AM
SlvrJdm's Avatar
Default Cv Axle And Cv Axle Seal
i haven't taken out the cv axle out yet but if i did would i need to replace the cv seal? Also would it be easy to take it out and replace? What tool would i need for it? thank you
Old Oct 25, 2012 | 11:37 AM
Former User's Avatar
Default Re: Cv Axle And Cv Axle Seal
It's easy to replace the seal. No special tool is required. Why do you want to?
Old Oct 25, 2012 | 12:50 PM
h22ekguy's Avatar
yeah, why would you want to? what's wrong with it in the first place?
Old Oct 25, 2012 | 01:41 PM
SlvrJdm's Avatar
It been old im just afraid it will leak. : \
Old Oct 25, 2012 | 01:55 PM
Buy new seals from Honda.
Remove axles. (It may help to drain the transmission fluid before you do this.)
Gently pry old seals out with a screwdriver.
Wipe clean the surface of differential contacted by the seals.
Evenly press each new seal into the differential, just until flush with the outer surface of the differential. I tapped the seals with a clean flat piece of wood to get them flush.
Grease the inner ring surface of the seal that contacts the axle and do the same on the matching surface of the axle.
Install new axles.
Old Oct 28, 2012 | 01:20 PM
SlvrJdm's Avatar
bad news! before i can even start on the axle. My cv axle nut seem to be screw up it won't come out no matter what even if i use a torque wrench or a breaker bar it still stuck. what is my best option?
Old Oct 28, 2012 | 01:26 PM
Did you lift the nut tab and soak in PB blaster?
Old Oct 28, 2012 | 01:49 PM
jbpnoman's Avatar
Go to your local tools store, and buy a 1/2" breaker bar. $15. Buy the 32mm socket. $3. To go your local hardware store, and buy a 3' length of lead pipe that fits around the breaker bar. Go to town on it.
Old Oct 28, 2012 | 03:38 PM
SlvrJdm's Avatar
yeah i have all those and i did all those step but ended up still struggling. : \
Old Oct 28, 2012 | 06:24 PM
Only one thread is allowed per topic.
driveslow
19
Mar 5, 2009 07:03 PM
Keewun
Dec 20, 2004 04:21 AM
digital sol
Oct 30, 2004 12:06 PM
sinfulDB1
Dec 2, 2003 10:53 AM
AndyD
Jan 28, 2003 04:20 PM
