help a girl out
Old Oct 24, 2012 | 03:55 PM
Angela Gray's Avatar
Icon2 help a girl out
having problem w stick shift its getting stuck like the lock is on. it got stuck while in drive last time went to go into park would not go past neutral. second time would no go into gear from park, cant even push in button. any ideas
Old Oct 24, 2012 | 04:04 PM
Black R's Avatar
25 Year Member
Default Re: help a girl out
Is your sister named Sasha?
Seriously though, what year and model car?
Auto trans?
When was the fluid last changed?
Old Oct 24, 2012 | 04:35 PM
jdowen2's Avatar
Interlock system between brake pedal and trans lever. Cable could be out of adjustment. Search
Old Oct 24, 2012 | 05:08 PM
Hidenplanvew's Avatar
Brake switch could be bad, its a 20 buck part. can you use the bypass on the shifter to move it around? The brake switch will lock you out if it dosent see the brake peddle pushed in
dgarrison123
May 30, 2008 09:14 AM
firemansteve
Oct 1, 2007 05:44 PM
Jedimiah
Jun 8, 2007 11:04 PM
socaleg6
Dec 11, 2005 11:27 AM
greaselightning
Feb 12, 2003 01:17 PM
