Honda CR-V & Element 2WD & 4WD Element & CR-V
Simple question about B20Z intake manifold?
Old Oct 24, 2012 | 11:48 AM
shermanyang's Avatar
Default Simple question about B20Z intake manifold?
I'm just curious if anyone here knows what that big canister is for on top of the shorter running B20Z intake manifold is for? Has anyone removed it and does it run fine without it? I really see no use having it up there but maybe it does serve a purpose that I'm just totally aware of....
Old Oct 24, 2012 | 02:59 PM
civiceg94's Avatar
Default Re: Simple question about B20Z intake manifold?
Can tell you what use its for but if you take if off youll see inside you intake manifold
Old Oct 24, 2012 | 10:50 PM
NZ-DB8R's Avatar
Resonator, to reduce induction noise
Old Oct 25, 2012 | 06:43 AM
I see....so that's all it is. I guess it really doesn't need to be there if you already have a loud car lol. Thanks NZ-DB8R
Old Oct 25, 2012 | 03:55 PM
www.megameet.org's Avatar
I thought it was to have air available for more tourque, like larg aftermarket intake manifolds, and the early giraffe crv manifold.
Old Oct 25, 2012 | 09:35 PM
I wouldn't think that would be possible with a encloser as such. It's like putting a jar to your mouth and selling it and trying to suck air out of it...that's just my impression of it.
Old Oct 25, 2012 | 11:50 PM
neu-b's Avatar
I have herd it is a resonance chamber to help produce tq. I have seen people take them off and cap it with rubber.
Old Oct 26, 2012 | 12:18 PM
Yeah you can take it off and cap it. On the giraffe manifold, if you swap it out or like a blox or skunk 2, you will lose tourqe... That plastic piece should have the same result
Old Oct 26, 2012 | 03:50 PM
NZ-DB8R's Avatar
Not true, the tq comes from the much much longer intake runner length of the "giraffe" manifolds.
Shorter intake runners are good for higher RPM power, longer runners better for low RPM power.
Look at ITB set ups, longer trumpets from low RPM, shorter trumpets for high RPM
Old Oct 26, 2012 | 06:23 PM
Charlie Moua's Avatar
take it of put a filter on it, or else just get rid of it and get a blox IM...
one of my guys on mnhondas has a preformer X manifold for cheap. i can lowball him to sell it for like $150.. lol
Old Oct 26, 2012 | 07:36 PM
NZ-DB8R's Avatar
The last thing you would want to do is put a filter on it. Would make the car run like **** due to introducing air into the manifold/engine after the MAP sensor (hot air too)
Old Oct 26, 2012 | 08:42 PM
neu-b's Avatar
Yeah, a filter on it is a horrid recommendation.
Old Oct 27, 2012 | 10:01 PM
19dabeast85's Avatar
Lol. Go ahead and remove it or put a filter on it and start your engine.... Wonder what happens when the world becomes your plenum, maybe a black hole? Lol.
The chamber is there to increase plenum volume which increases torque in the lower rpms. It would be interesting to see a dyno comparison with it removed and capped off to see if the upper range is hurt by the chamber.... I doubt it but would be nice to know.
Old Oct 28, 2012 | 05:03 PM
crexer's Avatar
lol ^^^ can that be my signature? The world is my plenum. What are you guys capping it with?
Old Nov 4, 2012 | 07:29 PM
SpooLinEg6's Avatar
Ive ran my v with a BG LS2 cap upside down in it using the oe rubber from the chamber. I have a cool air intake and a nice custom 4 into 1 thermal wrapped header with cat delete extension bung and full 2.5 all the way back on my aWD manual.. The decision to put the chamber back on came quickly because the power gain was MINIMAL ,short lived and was not worth the midrange torque lost... Now with a Vtec head the Blox or skunk would be worth the money because the flow characteristics change.. but in stockish form (no vtec) im pulling all i can with the chamber
Old Nov 5, 2012 | 10:55 AM
Interesting...I'm glad I asked because now it seems like this chamber has multiple purposes. I guess I'm just gonna keep it on until I drop in the new motor. Until then, it'll just be an eyesore that helps with the up-and-go tq.
0260MOTORSPORTS
Oct 12, 2006 08:31 AM
Soccerking3000
Welding / Fabrication
Dec 12, 2005 09:51 AM
JBBNJ609
Apr 17, 2005 03:00 AM
Sincere
Mar 28, 2003 09:35 AM
