steering and tire wear problem
Old Oct 23, 2012 | 03:20 PM
Angry_Raisin's Avatar
Default steering and tire wear problem
i have a 94 honda civic ex and now i' have replaced the controll arm pushing with the poly.bushings, the steering rack and outter tie rods. i have also changed out the upper control arms to the skunk pro plus, ajustable upper ball joints cause when i did the alignment the camber was off. so now i have everything on the green in the alignment rack but when i press on the gas the steering wheel turns 90 degrees to the left and when i press on the brake the sterring wheels turns 90 degrees the the right (note the car is completely stock other then whats mention)
PLEASE HELP!!!
Old Oct 29, 2012 | 08:02 AM
Deth Sol's Avatar
Default Re: steering and tire wear problem
Recheck all your upper and lower control arm bolts and also check the subframe bolts.
Old Oct 29, 2012 | 06:55 PM
crzycivic93's Avatar
damnnnn u got an issue.... Try switchin the front 2 tires. Drivers to passengers, and vice versa
Old Nov 4, 2012 | 06:36 AM
i checked all of the bolts on the suspention. all the subframe bolts, upper and lower control arms, and the rack bolts everything is bolted on tight. the tires r brand spankin new. and i did swap them to the back n i still have this problem. im losing my mind. i even changed out all the motor mounts
Dilbones
Jul 14, 2017 02:37 PM
dh1212
Mar 14, 2016 01:17 AM
VTEC_Du_Ma_Mai
Feb 27, 2008 07:01 PM
Red_ED8
Oct 3, 2005 02:22 PM
vtec_crazy
May 30, 2005 10:23 AM
