over heat
Old Oct 23, 2012 | 11:40 AM
chieuxuan's Avatar
Default over heat
Hi, my name is Henry, I am new here so please be easy on me....lol. I just purchased a 96 EX cpe 2.2L, I am having problem with over heating when sitting at a stop light or idling for more than 2 mins. Whenever the temperature needle goes up, I step on the gas and rev it about 1500 rpm, temperature goes down. Coolant level is in check, fan is on. Previous owner (friend of mine) told me that he already change timing belt and water pump about 25K miles ago, car now has 162K. What could it be?? Thanks a million!!!!!!
Old Oct 23, 2012 | 12:12 PM
doctorbee's Avatar
Default Re: over heat
sounds like a bad water pump. did he use OEM Honda? you may want to pop the cover off and look for any coolant leaking out of the weep hole on the pump itself
Old Oct 23, 2012 | 12:20 PM
chieuxuan's Avatar
Thanks, there is no water leak that I can see, I don't even smell coolant when I lift the hood, I don't know about he used an OEM water pump though.....
Old Oct 23, 2012 | 01:33 PM
Fitz Williams's Avatar
10 Year Member
You suppose he bled the cooling system? Not very hard to do.
Old Oct 23, 2012 | 02:09 PM
chieuxuan's Avatar
That I don't know, his dad is a mech. so he should know better. I think the car being sit for so long, prob the thermostat freeze up. I'll take it to my friend's shop tomorrow to ck it out. This engine is way more quiet than my 05 TL.
patoloco008
Aug 29, 2013 11:42 AM
snowblind7x
Sep 3, 2008 01:31 PM
wedtm
Mar 26, 2008 07:59 PM
phanatic
Jul 9, 2006 07:47 PM
RedRyda
Jun 16, 2004 04:41 PM
