Rough idle B series.
Old Oct 23, 2012 | 10:53 AM
skaraider's Avatar
Default Rough idle B series.
car info
94 Civic
B17 gsr motor
Hydro trans
Turbo
I have really rough idle after the car warms up, infact it won't idle at all after its warm only when its cool.
So here is what I have done.
Took the IACV off cleaned it out everything seems to be fine,
Took the Throttle body off cleaned out all the ports
Took the other valve on the Throttle body off and tightened the big plastic screw on the inside.
Ran fine for a few days then the idle problem started back,
Currerntly I have the Throttle body off the car.
What else am I missing?
Old Oct 23, 2012 | 12:50 PM
EFinAwesome's Avatar
Default Re: Rough idle B series.
the other valve is the FITV. If you tightened it and it ran fine for a couple days I'd assume it came loose again. Tighten it ip again and secure it or....
https://honda-tech.com/forums/acura-integra-6/bypassing-iacv-fitv-coolant-lines-2949982/
Old Oct 23, 2012 | 03:40 PM
skaraider's Avatar
So if i tighten it all the way down..... and secure it, does it need to be all tight? or? just slightly, or if i block it off... can i just loop the coolant lines? I checked the thread but i didn't see where it said for the lines to go.
Old Oct 23, 2012 | 05:46 PM
hybridmiklo's Avatar
is it tuned?
Old Oct 24, 2012 | 02:24 PM
skaraider's Avatar
yes
Old Oct 24, 2012 | 02:33 PM
lude72's Avatar
do away with it and retune
Old Oct 24, 2012 | 05:46 PM
skaraider's Avatar
easier said than done, nearest tuner is 3hrs away
Iloveyourhonda92
Apr 11, 2015 07:46 PM
twentyhurtz
Dec 5, 2008 07:30 PM
neldogg
Nov 17, 2007 03:52 PM
afterburners
May 9, 2004 04:37 AM
FourthGenHatch
Apr 29, 2002 11:08 AM
