'96 'Teg LS/Vtec Pwr/Str Pulley and Nut
Old Oct 23, 2012 | 08:44 AM
USMCxTeg's Avatar
Default '96 'Teg LS/Vtec Pwr/Str Pulley and Nut
Ok, so after the help and advice with my last post, I need to find a Power Steering pulley and nut. The car still has the factory pump even after the VTEC conversion, so the pump was easy to find, but whoever installed it seems to have welded the nut on (took it to parts store and they couldn't get it with a pneumatic wrench, or a 6 ft breaker bar). The nearest dealer is in Atlanta, which is about 2 1/2 hours from here, and I found one from a factory direct website for about $45, but no one seems to have the nut in stock. So, if anyone knows of a better price (or a Civic/Honda part # that is interchangable), or if I should just go aftermarket?
After this, gotta get new front tires. Someone decided to have 205/50-15's installed, so my speedo is whack Still get 34mpg though!
Thanks
Old Oct 23, 2012 | 11:05 AM
fcm's Avatar
fcm
Old Fart
Default Re: '96 'Teg LS/Vtec Pwr/Str Pulley and Nut
http://www.acuraautomotiveparts.org/...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
Or, have you checked your local bone yards, [PicknPull]? 94
Old Oct 23, 2012 | 11:26 AM
USMCxTeg's Avatar
Excellent site, thanks a lot. I've checked the salvage yards around here, not a whole lot for anything Honda/Acura.
Old Oct 23, 2012 | 04:46 PM
fcm's Avatar
fcm
Old Fart
That's too bad, we have a chitload of them...
http://www.picknpull.com/check_inven...ra&Distance=20
http://www.picknpull.com/check_inven...rd&Distance=20
http://www.picknpull.com/check_inven...ic&Distance=20
http://www.picknpull.com/check_inven...-V&Distance=20
http://www.picknpull.com/check_inven...de&Distance=20
Even a few Vigors and Legends and RSXs 94
discgolfer
Aug 9, 2017 12:23 AM
miamatt
Feb 18, 2015 11:01 AM
USMCxTeg
Oct 15, 2012 03:42 PM
zracer240
Feb 3, 2006 05:13 PM
rough_draft
Oct 27, 2004 11:33 AM
