Rev (rpm) sticking
so from the other day ive been noticing that sometimes while im driving i come up off the gas pedal, but the rpm isnt goin down .. and then recently in traffic after moving up a few feet and having to stop i see that it sticks at 2000rpm .. ive seen it go higher but thats the general area that its been holding the rpm
so i check to see if the accelerator cable was sticking .. it wasnt but i even went as far as to grease just in case .. but its still doin this
i recently changed by intake manifold but havent gotten a chance to tune the car ..
somebody said something to me .. that it could b the idle valve goin crazy because i havent tuned ..
is that correct ?? have any of u ever experienced this ??
my gsr seems to do the same but its only with the edelbrock throttle body. if I switch to a regular Honda throttle body it doesn't do it. I've had it off many times, I don't know what it is and it only does it after a good full throttle mashing.
Posted from Honda-tech.com App for Android
i dont have to go full throttle for it to hold the rev .. and as far as TB goes its the stock b16a TB i think 62mm or something like that .. so not sure if that has anything to with it ? granted the TB was changed the same time as wen i changed my IM to the p30 one
been observing it more .. as its been happening more often ..
ok driving .. come off the gas .. rev stay right whereever i was i was at ,, 2k rpm .. 3k rpm .. but once it starts doin that i jus tap the gas pedal and the revs drop back to normal .. lol right now i use it like cruise control sometimes .. but it only started happening after i changed intake manifold ..
as i say i was told that its the idle valve sensor .. and that it will be fixed once i tune but some how it jus seems strange to me .. was jus wondering if anybody else experienced this b4 ..
Sounds more like something is sticking, if it will do it while you are parked with the hood up set it so RPMs are up and then check to see if TB cable cam as returned all the way back to the stop. 94
Any updates???
my car is doing the same. I have an Erick's Racing 68mm TB on a b16 sk2 manifold. Just recently at the IFO Phoenix race...the TB or cable was sticking and the revs was shooting up to 8 or 9k when I start the car. I have to immediately kill it.
What would cause the throttle cable to stick? How to fix it?
What would cause the butterfly to stick? How to fix it?
Any updates???
after this tho i changed TB to the euro R one .. had the same issue .. but i then came to realize that the euro r TB doesnt come with the screw so u can turn down the idle .. instead its located right under the throttle lever ..
jhoffy22
Oct 17, 2013 03:49 PM
