Won't go into gear, even with motor off!
Old Oct 23, 2012 | 05:57 AM
Brandon H.'s Avatar
Default Won't go into gear, even with motor off!
My buddy called me this morning, saying his car won't go into gear, even with the car off. He said it worked fine yesterday. It's a 95 d series, I'm not sure where to start looking, but I'm guessing a linkage or low tranny fluid? Where should he start?
Old Oct 23, 2012 | 06:05 AM
Emeraldbomber's Avatar
Default Re: Won't go into gear, even with motor off!
Linkage
Old Oct 23, 2012 | 06:38 AM
mayfly's Avatar
take the shift linkage off. try to move the shifter pin by hand. if you cant then its your tranny. if you can then its the shift linkage
Old Oct 23, 2012 | 06:53 AM
L1lKraYzi3's Avatar
Most likely your shift linkage. and also check the shifter bushing and see if its not torn. then check if you have clutch fluid.
Old Oct 23, 2012 | 01:27 PM
bksfinest91089's Avatar
Shift linkage but check the tranny fluid also
Hatchbacksonly
Dec 2, 2012 04:20 PM
dsd1_209
Transmission & Drivetrain
Nov 1, 2012 06:53 PM
Lokisdope
Apr 1, 2008 11:29 AM
honcrx91si
Aug 25, 2006 08:24 PM
gabrielle
Jul 3, 2006 10:04 PM
