GSR onto EK Civic Problem (Pics inside)
Old Oct 22, 2012 | 07:18 PM
jrunager's Avatar
Default GSR onto EK Civic Problem (Pics inside)
Ok so I was pulling the endlinks off of my DC2 sway bar prepping it for an install onto my 97 Civic LX when I get my Moog endlinks in. Well one of the endlinks bolts was seized on pretty good and snapped off inside of the endlink. The other end of the sway bar had no issues and still has the bushing installed.
So what do I do to fix this problem? This may be common knowledge for some of you but since this bushing was for an Integra endlink does it need to be replaced or can it all be bolted together without bushings?
Also the last picture is of my d brackets. Do these fit my civic as is, with modification or not at all? The look a different than SI D brackets with that curve in them so from the looks of them I don't think I can use them unless I can add some sort of space maybe.
Thanks in advance.
Old Oct 22, 2012 | 07:20 PM
jrunager's Avatar
Default Re: GSR onto EK Civic Problem (Pics inside)
This is my D bracket. It looks so different from the SI D bracket I'm not sure it will work. The top portion is recessed back so far I'm not sold on it working unless the SI ones are the same and the pictures I see are just deceiving.
Old Oct 23, 2012 | 09:21 AM
rice a roni's Avatar
what?
look if you're looking at putting a gsr swap in your civic you need a b series del sol or em1 rear t bracket. not some d series si bracket.
about your sway bar link...just get a new one or else it will make clunking noises and be useless.
Posted from Honda-tech.com App for Android
Teh Boss
Dec 30, 2012 07:48 PM
illdstu
May 10, 2004 03:20 PM
gubo22
Sep 21, 2003 04:20 PM
